2 members (Peggy M, crenwelge), 173 guests, and 3 robots.
Topics128,077
Posts1,056,015
Members48,433
OK, So how is it done. Getting Corn Head Grease into the Steering gear? While in the truck if possible>
Julian Carter
1970 Triumph GT6
1967 Triumph TR4A
1952 Chevy 3600
1948 MG-TC
Julian,
Just put the tube of corn head grease into a grease gun and start pumping it in through the fill hole. Should be a 7/16 square head plug on top of the steering box. Just remover it and pump the corn head grease into that hole. Corn head grease is a self leveling grease so it will take a little while to get the steering box full. My steering box took a complete tube plus another 3/4 of a tube, but I had completely cleaned out my steering box. Emptied one full tube and then let it set overnight. Placed the remaining 3/4 tube in the next day.
Hope this helps.
Tim
1970 VW Beetle
Didn't want to buy another grease gun just for the corn head grease so, I just put on disposable nitrile gloves and use my hands.
Larry Kephart
1937 Chevy Utility Express (Deerslayer)
1955 1st 3100 Chevy (BillyBob)
2017 Cadillac ATS-V (Elvira)
Boca Raton, Florida
e-mail: [email protected]
http://www.laroke.com/larryk4674/1998/billybob.htm
I pushed all into a heavy plastic bag and used it like a cake decorator would. Snip the corner off and squeeze it in.
Joe
Plastic squeeze bottle. Don't put the spout tight into the hole or the air can't get out.
You don't need to buy another grease gun to install the corn head grease. Just remove the tube of grease you have in the gun and clean the top cap. Place the corn head grease tube in the gun and after a few pumps of the gun into a rag the corn head grease will be the only grease coming from the grease gun. I was concerned about the same thing but was assured by a local Chevrolet suspension specialist that he does this all the time with no problems.
Tim
1970 VW Beetle
H Online: Content
Ziplock freezer bag with one corner snipped off- - - - -squeeze and go!
I think you guys like mentioning corn head grease. How is it different than regular grease for us neophytes, and when in general should we think about using it? Don't mean to sidetrack the post, but it has come up a lot recently.
Allen
1974 Stingray Corvette
1 Offline
Corn head grease is NLGI 0 which means it is much thinner, which means it will flow. It will self level in the gear box and fill back into the bearings to lubricate them. Regular chassis grease is more firm and will stay in place so the grease will be pushed out of the bearings and will not flow back into them.
There are large grease fittings available that work great for this.
Where are these available? Would they thread in the same hole as the fill plug?
00 and 0 are self-levelling greases (probably at normal, 70 degree temperatures). 000 is, of course, thinner.
Supposedly, the original GM steering box grease was 00
Penrite steering lube is 00
I'll settle for 0 because it is readily available.
24601
Dougs -- Save your $$$ and time -- Just stick the tip of your grease gun in the fill hole and pump. It worked fine for me.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
