7 members (Peggy M, Hambone, 68ironhead, 2-Ton, TUTS 59, DaveV, msmall),
54
Mod | | | Forums66 Topics128,009 Posts1,055,296 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2003 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: May 2003 Posts: 47 | Hello Iam having problems with my hood. All the way in the back is wiggleing like it need it a support or something. I notice about 12 inches from the back there is a support bracket but there is a gap of about 1/4 inch, doesn't that needs to be glue down to stop all the wiggleing that I am having...Once again thanks for all the help. | | | | | Joined: Jul 2003 Posts: 106 Member | | Member Joined: Jul 2003 Posts: 106 | Wish I knew more and could help  , but I'd bet someone is going to ask you what year/style of truck you've got.
51 Chevy 1/2 ton-Restored 46 GMC 1 1/2 ton-Farm Fresh
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | Seadog, I have sent you a file that explains how to align a hood for the Advance Design series. I found this on another website some time back. Hope it helps. | | | | | Joined: May 2003 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: May 2003 Posts: 47 | Houston thanks a lot. My truck is a 49 and I think it needs some type of gasket or glue in the support, since when I hold it down like the left side it looks good. Houston what you send me will help me a lot since I also have to adjusted thanks | | | | | Joined: Sep 2004 Posts: 117 Member | | Member Joined: Sep 2004 Posts: 117 | My 64 has a rubber type insulator between the inner hood brace and the hood. It was held in place by a glue of some sort. If you remove the brace you may find scraps that will give you an idea of what was there. | | |
