2 members (78buckshot, 1 invisible),
390
Mod | | | Forums66 Topics128,162 Posts1,057,042 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2014 Posts: 1,293 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,293 | I need to remove the starter on my 1954 , 3600, 235 Engine. There is very little clearance to get a wrench on the top bolt. I've tried every 3/4 open end wrench I have and there's no room to turn the wrench. I cant get a box end on it at all due to little end clearance. Can someone tell me the correct method. Thanks
Ron - - Dusty53 1954 Chevy 3604In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel." | | | | | Joined: Feb 2004 Posts: 29,871 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,871 | I use a 3/8" drive 3/4" universal socket and enough extension to work the ratchet from just behind the starter motor. Jerry
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Years ago I took a cheapy 3/4 box wrench & heated it with the torch & bent the end to about 90 degrees. It works good on those. If you are in the K. C. ,area I will lend it to you.
They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jul 2014 Posts: 1,293 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,293 | Thanks Hotrod and Wrenchbender , looks like I've got a non-standard starter and bending a wrench or getting a 3/4 "starter wrench" may do the trick. It looks like I should have took that starter off the first time it "acted up" now it died while trying to start the old girl, its "dead", won't do a thing. The PO switched to 12V system and this is definitely not the original 6V starter. Now to get it off and see what the problem is.
Ron - - Dusty53 1954 Chevy 3604In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel." | | | | | Joined: Jul 2014 Posts: 1,293 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,293 | Men, I finally got that top bolt out and found a mess after I got to checking it over. I started a new post "Starter Woes, Need Help". If ya get a chance take a look. Thanks for the help.
Ron - - Dusty53 1954 Chevy 3604In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel." | | | | | Joined: Oct 2015 Posts: 3 New Guy | | New Guy Joined: Oct 2015 Posts: 3 | Back in my high school days in the 50's I had a "starter wrench" that I used for that task. | | | | | Joined: Jul 2014 Posts: 1,293 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,293 | Perhaps I should add one of those to my tool box. Probably wouldn't have to worry about it "walking off", they wouldn't know what to do with it. Thanks for the info!
Ron - - Dusty53 1954 Chevy 3604In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel." | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It seems to me the wrench size on the old stovebolt engine starter was 3/4 in. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | It seems to me the wrench size on the old stovebolt engine starter was 3/4 in. Recently took off a starter, and you are correct with the bolt/nut size. Access to the top stud is a bugger, I don't know what GM was thinking at the time as one can only get about 1/16-1/8 turn with a 3/4 open end. I make sure the threads on the stud and nut are in good clean condition so that the nut can be finger tightened (or loosened) most of the way. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | As I recall, the nut on the switch is what takes a 5/8. | | | | | Joined: Jul 2014 Posts: 1,293 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,293 | Yes, it was 3/4. What made this even more of a problem is that it was a 12V car starter and there just was very little clearance between the solenoid housing and the bolt head. When I put it back together using the correct 6V starter, I installed a stud in the top bolt hole. That made it easier to install.
Ron - - Dusty53 1954 Chevy 3604In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel." | | | | | Joined: Jul 2014 Posts: 1,293 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,293 | Paul_WNC , right, its still a tough top nut! One of those curved wrenches might have helped.
Ron - - Dusty53 1954 Chevy 3604In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel." | | | | | Joined: Jun 2012 Posts: 1,749 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,749 | I forgot that I have 2 of these. One is 9/16 -5/8 and the other is 11/32 - 3/4. So never look just grab both and use what fits. Silly me. I did manage one fine day in my youth to create one. Used a Fo%$ damper pulley nut with the wrench placed against the frame. Starter motor did the bending. Should have seen the look I got from the counter guy at Sears. I am not a big guy(150 and 5 ft 7) at the time). My buddy who went with me was 6 ft 5 and well over 300 so I just hooked a thumb over my shoulder and got a new wrench.
Steve H
