4 members (dogdaddy, Ponchogl, 2-Ton, 1 invisible), 72 guests, and 2 robots.
Topics128,037
Posts1,055,463
Members48,422
#1129513 10/14/2015 8:19 PM
going to pick up a 261 someone posted as a 216. its a 58 motor with a 848 head. one problem, its frozen! figured its worth a shot for $100. maybe ill keep it as a spare, or maybe ill try to break it free and sell it. I have a 62 261 im getting ready to rebuild this next summer.
The block alone is worth twice that amount, even if it needs to bored and/or sleeved. That 3 3/4" bore size is unique to the 261- - - -virtually all the other parts except the connecting rods and pistons will swap from a 235.
Kinda what I figured too about saving the block worst case.
Tearing into it now....pulled drain plug, FULL of water!
Gas Pumper
Gas Pumper
Don't be too quick to discount the engine because of that. The oil soaked metal over the years may have saved it. Perfect combination. It has full flow oil filtering, has the highest compression head. Keep us posted!
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
Well, I got fooled by a 53 235 the bars by the starter. Gonna sell the 848 head. Are these 53 blocks worth much?
The 1953 Power Glide 235(which you have) is the first full pressure 235. It is a very good engine. I am sure you will find it easy to find a good home for it.
My Blog
Ok, so not a bad deal after all. The 848 is a '58 and looks to be milled. Plus the block has been bored .40 over with nice looking cross hatched cylinders. Broke it free. Gonna pull the pan tomorrow......
I am running one of those jewels right now. It is a great motor. With the hydraulic lifters, you can't hear the thing running at idle. Direct bolt in to replace a 216. Only issue is the hole in the crankshaft for the pilot bearing is too small for a standard sized pilot bearing. There is a correct sized one available however.
Carl
Thanks for the info
The guy I got it from, came out of a 53 truck with a 4 speed behind it.
Good information.
