7 members (1955 1 Series, Peggy M, mk72, Shardean, 55shaker, Uncles51, fonz8261),
59
Mod | | | Forums66 Topics128,022 Posts1,055,387 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 114 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 114 | going to pick up a 261 someone posted as a 216. its a 58 motor with a 848 head. one problem, its frozen! figured its worth a shot for $100. maybe ill keep it as a spare, or maybe ill try to break it free and sell it. I have a 62 261 im getting ready to rebuild this next summer. | | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | The block alone is worth twice that amount, even if it needs to bored and/or sleeved. That 3 3/4" bore size is unique to the 261- - - -virtually all the other parts except the connecting rods and pistons will swap from a 235. Jerry
| | | | | Joined: Apr 2010 Posts: 114 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 114 | Kinda what I figured too about saving the block worst case. | | | | | Joined: Apr 2010 Posts: 114 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 114 | Tearing into it now....pulled drain plug, FULL of water! | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Don't be too quick to discount the engine because of that. The oil soaked metal over the years may have saved it. Perfect combination. It has full flow oil filtering, has the highest compression head. Keep us posted! | | | | | Joined: Apr 2010 Posts: 114 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 114 | Well, I got fooled by a 53 235 the bars by the starter. Gonna sell the 848 head. Are these 53 blocks worth much? | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The 1953 Power Glide 235(which you have) is the first full pressure 235. It is a very good engine. I am sure you will find it easy to find a good home for it.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Apr 2010 Posts: 114 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 114 | Ok, so not a bad deal after all. The 848 is a '58 and looks to be milled. Plus the block has been bored .40 over with nice looking cross hatched cylinders. Broke it free. Gonna pull the pan tomorrow...... | | | | | Joined: Mar 2010 Posts: 10,271 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,271 | I am running one of those jewels right now. It is a great motor. With the hydraulic lifters, you can't hear the thing running at idle. Direct bolt in to replace a 216. Only issue is the hole in the crankshaft for the pilot bearing is too small for a standard sized pilot bearing. There is a correct sized one available however. Carl
| | | | | Joined: Apr 2010 Posts: 114 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 114 | | | | | | Joined: Apr 2010 Posts: 114 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 114 | The guy I got it from, came out of a 53 truck with a 4 speed behind it. | | | | | Joined: Jul 2014 Posts: 22 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 22 | | | |
