1 members (Peggy M),
95
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,101 Posts1,056,182 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 9 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 9 | I'm reassembling my 1950 3100 (formerly someone else's project), and have run up against a problem with the bed. The bed sides I have are about 2" too long, suspect they may be from a GMC. I'm considering whether to just lengthen the frame a couple inches--any suggestions on where to get 9/64 steel for extensions? I could get different sides, but these are very straight.
Thanks, Warren 1950 Chevy 3100 3 Window ("it ran when I parked it")
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | GMC and Chevy short beds used the same sides. What makes you suspect they are too long? The bed sides don't attach to the frame. | | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | The bed sides stick out past the rear frame stubs by about 2 inches. That space is filled by the rear cross sill that has the little step for the bed wood boards to sit in. | | | | | Joined: Apr 2008 Posts: 9 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 9 | Thanks for the replies--I do think I've got the basic assembly configuration figured out, and "something ain't right" as we say here in NC.
With the bed partially assembled, the back bed sill is about 2" shy of where it should be in order to attach to both the frame and the bed sides.
I'll try to attach some pictures tonight with more details.
WP 1950 Chevy 3100 3 Window ("it ran when I parked it")
| | | | | Joined: Apr 2008 Posts: 9 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 9 | Should also add--my first thought was that someone cut the frame shorter, but on inspection, that doesn't seem to be the case.
| | | | | Joined: Aug 2012 Posts: 131 'Bolter | | 'Bolter Joined: Aug 2012 Posts: 131 | How long are your sides?
| | | | | Joined: Aug 2012 Posts: 131 'Bolter | | 'Bolter Joined: Aug 2012 Posts: 131 | The bed sides on my 1949 3100 are 79 and 5/8 inches measured along the top rolled over round edge
| | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | Yes, that measurement checks out perfectly. 79&5/8" . Not sure exactly where your fitment issue is. Please get some photos up and we can figure it out. | | | | | Joined: Apr 2008 Posts: 9 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 9 | Thanks for the measurements 1866--I'll check the sides tomorrow. Here's a rear view of the back of the right bed side: Pic 1 and a left view of the front bed panel: Pic 2 The DPO (dreaded previous owner) patched/welded the front bed; I'm wondering if that was done incorrectly? Even if that's the case, would not explain the whole 2" problem.
| | | | | Joined: Sep 2010 Posts: 252 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 252 | I am not sure I understand pic 2. Can you post some more pics? Mine is one the hoist right at the moment so I could do some measurements and pics to help (?) | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | How close is the front panel to the back of the cab? Couldn't tell from your photo.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I think I might see the problem. In pic #2, I believe that you might have the cross sill in backwards, and that the front bed panel actually mounts to the front of it, rather than behind. Just eyeballing it, that looks like it would make for the mystery 2" that the rear is off.
Bill Burmeister | | | | | Joined: Aug 2012 Posts: 131 'Bolter | | 'Bolter Joined: Aug 2012 Posts: 131 | Looks to me like you just have the sill in the wrong position. Looks like the rear sill needs to move back and the whole bed moved forward. Look at the pictures in the thread below for some decent reference pictures of how the bed goes together and the location of the rear sill. There are some bed pictures down lower on that page. (Page 2) http://67-72chevytrucks.com/vboard/showthread.php?t=541111&page=2The truck in that thread is not mine and I know nothing about it. It just came up when I googled a topic and I saw it had some good pictures. I haven't looked through all of the pages but it looks like a very nice truck and looks very well done. Good luck
| | | | | Joined: Apr 2008 Posts: 9 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 9 | Longbox, I wondered about that. The front bed panel was repaired at some point, and I wondered if it had been welded back together with the bottom lip attached incorrectly.
In answer to someone else's question, the front bed panel is about 3½ to 4" from the back of the cab, and it seems like too big a gap. That is consistent with the front bed panel being incorrect.
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | The front bed panel should be about an inch or slightly less from the rear of the cab.
| | | | | Joined: Apr 2008 Posts: 9 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 9 | My bed sides do measure correctly (79 5/8"), so that's not the problem; the front bed panel is indeed too far from the back of the cab as mentioned in previous posts. The front bed panel repair by the previous owner may be the problem. The mounting of the front bed sill is pretty well fixed by the existing holes in the frame, which do not appear to have been relocated by the PO. Here are some better pix of mine: L side front sill 1 L side front sill 2 (these 2 pix display as cropped, not sure why) And here is a picture of a bed off the web--clearly shows the panel mounted to the front of the sill, but the resolution does not permit viewing of much detail: bed assy web pic Can anyone post pictures of a correctly installed front bed panel, specifically the bottom? Thanks, Warren
| | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | Warren, I'm pretty sure this is what you need to do. If I'm wrong I'm positive someone will help out too! The front cross sill bolts directly to the front panel lip. It does not sit under it. You have it on the wrong side. In your first picture you need to remove cross sill, spin it 180' and remount to the back of the front bed panel lip on the rear end side. This will move the bed forward the distance you need. When done the bed wood should sit on top of both the cross sill and the panel lip. This will also line up your bed wood holes and frame mounts. I believe the actual bolts that hold the box onto the frame have a large washer that sits on top of the bed wood and the bolts go through the bed wood, the cross sill and the wooden block to the frame. The bolts don't go trough the front panel lip. Hope this solves it for you.
| | | | | Joined: Apr 2008 Posts: 9 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 9 | Fox,
Oh duh.
The light bulb just (finally) went on, and you provided the juice! Methinks problem solved--thank you!
| | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | Glad to help! This site really is a great resource! | | | | | Joined: Apr 2008 Posts: 9 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 9 | Thanks to all for the replies. Simple in hindsight, but here's how to attach the front bed panel to the front cross sill: frt bed panel-cross sill config WP
| | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | | | |
