2 members (Hotrod Lincoln, klhansen), 119 guests, and 2 robots.
Topics128,127
Posts1,056,357
Members48,441
#113077 11/13/2001 5:37 AM
Don't mean to sound stupid....but what is filling primer? I've sprayed primer before but have never heard of this type. Is it used for filling in minor pitted areas?
thanks, Ken
#113078 11/13/2001 6:49 AM
I don't remember the term being used on a "label". But it would refer to any primer that is used for surfacing I would think. What a company uses as a name or description cold be misleading.
There are many different "primer surfacers" that would do filling. Everything from the old lacquer that barely fills 120 grit scratches with a couple of coats to polyester primer that could literally bury a quarter taped to your fender!
Is there a particular need you are after?
1948 Chevy Pickup
Chopped and sectioned
owned since 1974 when I was 15.
#113079 11/13/2001 7:18 AM
Filler primer is just what it sounds like. A heavy primer. I used some from DuPont and it worked great. It was a two part epoxy type. About two good coats is all that was needed. Then just block sand down and seal. You can really build up a area with this stuff. Joe
#113080 11/13/2001 8:52 PM
Filling primer is a "heavy solids" primer that will actually fill scratches and build up the surface. The slang name around here is "Bondo Primer". Like JoeH says, Block it out and you're good to go. It is a porous primer and will need to be sealed.
There is no problem so great that it cannot be solved by the application of thought, elbow grease and copious amounts of CASH.
Snappy
#113081 11/13/2001 9:56 PM
I would still treat it with zero-rust
#113082 11/13/2001 11:18 PM
Thanks everybody for the info....I wasn't looking for anything in particular....I was reading another post last night and they kept on referring to a filler primer and I wasn't sure as to what they were talking about. I understand it now. By the way, I did treat it with Zero Rust first.
thanks, Ken
#113083 11/14/2001 1:33 AM
SNappy, it doesn't need to me sealed, if it uses a hardener. I have seen the name "Filler" refered to many primers includeing some that have very little filling quality.
1948 Chevy Pickup
#113084 11/14/2001 2:26 PM
MARTINSR, You're right I was thinking of a specific product called .... Featherfill??? ... But there are catalyzed, filler primers, I've just never used one.
Snappy
#113085 11/14/2001 3:19 PM
Featherfill is a polyester, catalyzed primer and doesn't need to be seeled.
1948 Chevy Pickup
