Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
2 members (3B, 1955 1 Series), 36 guests, and 2 robots.
Topics128,009
Posts1,055,296
Members48,419
#1130652 10/21/2015 7:41 PM
1 Offline
Anyone have a good reference for DR generator numbers? I have a 12v generator 1102200 dated 0E17. This was on a 63 261 (cast D33) taken from a 1955 school bus. I can't find the generator number in my parts and accessories catalog (1929-1958) or my 1960's truck shop manual.
Joe D.
1962C10 #1130670 10/21/2015 9:21 PM
Best I could find was this:
http://www.delcoremy.com/find-a-part/product-details/1102200
So it was a good number that was "upgraded? To P/N:1102168 which is also "obsolete. The other searches I found sent me to a Studebaker site, so maybe it came from one of those? Any way it is rated at 12 Volts and 35 Amps so about the same as the Chevy part, I would guess. If it fits and the belts line up it should be OK. The Delco Remy site did not work very well in search mode.
Steve H
1962C10 #1130751 10/22/2015 5:45 AM
1102200 was originally used on 1960 Pontiac listed as Heavy Duty generator on cars with Heaters. 35 amp 12 volt. If you have an original one it would be heavy duty with cast iron end plates and ball bearing on the rear instead of the bushing rear plate. Most of this type generator had a heavy duty wound armature in them and even though only rated at 35 amps instead of 45 plus, it would have handled higher output on a more continuous basis than just a typical wound 35 amp generator....this goes back to the heavy duty armature.
Delco 1102199 and 1102240 were the same generator and used in 1961 Pontiacs with V8.
There you have it.
Ken
1962C10 #1130763 10/22/2015 11:00 AM
Thanks Ken, don't know what we're gonna do if something happens
to you.
I wish those catalogs were somewhere in public domain where they
could be preserved for future generations. Keith has tried to
preserve as much as he can with TOCMP. I'm always in fear of
loosing that resource also. I think any of these old listings
would sell like hot cakes if they were reprinted as some of
the vintage literature and shop manuals are.
Electrical and Carburation, the two most elusive and
incomplete data sources for a restorer.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
1962C10 #1130808 10/22/2015 4:31 PM
1 Offline
Thanks Ken. That explains why it was not in any of my Chevy references. And the 0E17 date code agrees.
Joe D.
