Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (ShopRag, farmallb, jasrking, TUTS 59), 34 guests, and 2 robots.
Topics128,010
Posts1,055,299
Members48,419
#1130515 10/21/2015 1:44 AM
Were rear side mount motor mounts ever made for an AD 3100 Chevy 216 or 235? Wanting to use them if they exist, for a 235 install on a 52 3100 that I'm planning on putting an automatic behind.
Joe
jremig #1130550 10/21/2015 4:00 AM
Side motor mounts as we know them today started in 1958 in passenger cars. I believe the first year for trucks was 1960. With that said I also believe the 1958 truck 235's had the mounting bosses cast on their block even though they weren't used.
So to answer your question, the AD trucks used front motor mounts and side bell housing mounts. If you want to install a automatic trans you will need a newer block that has side mounts and a crossmember for the trans tail mount or an old automatic trans (Hydromatic or Powerglide) that have bell housing mounts.
Maybe someone else has a different way to get around this issue that I'm not aware of.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
jremig #1130555 10/21/2015 4:18 AM
What kind of automatic? The cast iron Powerglide was offered behind a 235 but if using any other you will need an adapter which can be drilled and tapped for side mounts. The Powerglide had a cast iron adapter between the I6 engine and trans but maybe others could tell if it would be strong enough to hold mounts. I used a Bendsten's adapter behind my 37 Buick straight 8 to take a 2004R OD automatic and then used 55-57 Chevy auto trans bell housing mounts bolted to the steel adapter. The Buick and 235 Chevy are very similar engines in design---just longer.
Evan
jremig #1130576 10/21/2015 10:18 AM
Evan, do you have any pictures of that Buick installation?
I had a friend once that wanted to use one. I though it would be
a very unique swap, even though it would take some serious shoe
horning. Finding one without a busted cylinder wall turned out
to be a challenge.
DG
Denny G
Sandwich, IL
jremig #1130658 10/21/2015 8:03 PM
The transmission I'd like to use is a 200 4Runner od
