4 members (dt235sd, Rick Brown, Jon G, 2-Ton), 170 guests, and 2 robots.
Topics128,108
Posts1,056,238
Members48,437
#1130436 10/20/2015 5:54 PM
I'm rethinking how I've aimed my 12-volt fog lamp (NAPA 4412A). The pictures show the lamp and the pattern that I now have. I use it mostly to throw more light to the front but I'd still like to get it right.
Should the pattern be horizontal or vertical?
Should it be aimed a little low and to the right a bit? Thanks!
Fog Light.
Fog Light Pattern.
The whole idea of fog lights was to shine under the fog. We used to aim them by measuring the height of the light and them aiming them at a spot about 30 feet away on the same horizontal plane. They really didn't work that well but it helped some. We usually had them hooked directly to the battery with a toggle switch in a handy spot. In those days it was not that uncommon for headlights to go out. If that happened, you could flip a toggle switch and have some light.
We used to aim them straight out, not to the right because you want to see as much as possible and they certainly won't be in anyone's eyes.
A lot of thick shore fog in New England so you would be driving slow so aimed 2 to 3 car lengths ahead.
take the height to the center of the lamp, divide it by 3 and drop that amount for every car length.
usually 4 inches below the low beams at 20 feet out....
GMC: Get More Cash...
1958 GMC
My Webshots photos
Lucas flamethrowers on a momentary-contact starter button- - - - -windshield height to the guy who won't dim his lights!
Oooo thats nasty Jerry :o)
55 Chevy Stepside.
