2 members (Phak1, Pre '68 Dave),
215
Mod | | | Forums66 Topics128,095 Posts1,056,067 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2015 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2015 Posts: 55 | Newbie here , with a???? Just got this California rust free truck, no rust holes anywhere! All my shocks eye pins ,studs,(8 of them ) have no tread on the ends for the nuts,they all look the same,no tread on any of Them? So I gotta ask ,are they all broken off, or ???? Wish I could post a picture 4 ya , thanks guys , yep I"m a newbie
59 chevy apache fleetside
2007 dodge diesel 84 toyota 4 runner, v8,propane power
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Seems impossible they would all be broken. Need pictures. If you post them somewhere else, tell us where or read the instructions on here. You feed them to a picture hosting site and link. How are they held on????? If there are no nuts??? Are you positive this is a 1959 Chevy truck frame? If it is, I believe all 8 shock eyes are held with studs/nuts. Leaf spring suspension on all four corners.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | in my experience it's common that the threaded ends of those shock mount pins get twisted off when someone tries to get the shocks off .... just knock the swedged pins out and replace with good bolts - some new shocks even come with new bolts
Bill | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 |
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Oct 2015 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2015 Posts: 55 | Thanks guys, they must all be broken,thanks for the heads up on the shocks ,looks like a nother fix it job ,to add to the list , also will work on the picture thing later
| | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | I had one broken on my 59 Suburban, I drilled and tapped it for a 5/16 or 3/6 fine thread (don't remember which one) and put a grade 8 bolt in it with a Fender washer. It has been that way for the last 15 years as a daily driver. | | | | | Joined: Sep 2013 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2013 Posts: 36 | Funny thing, my 1959 3100 had the exact thing- all shock mount studs were smooth.....no threads to secure the shocks. I don't think they were broken off either- the ends look designed that way and the old shocks were a bear to get off of them. The rubber bushings in the shock eyes had the studs in a pretty good bind... | | | | | Joined: Jan 2014 Posts: 86 Shop Shark | | Shop Shark Joined: Jan 2014 Posts: 86 | Funny thing, my 1959 3100 had the exact thing- all shock mount studs were smooth.....no threads to secure the shocks. I don't think they were broken off either- the ends look designed that way... ChuckC, I recently replaced the original shocks on my '59 and encountered the same thing. That must have been how the original ones were designed. While I'm more comfortable with the new hardware, which has nuts, the original's without nuts held the shocks just fine for almost 57 years. Bob
1959 Chevy Apache Short Bed Step Side 1967 Cadillac DeVille Convertible 1967 Pontiac Firebird Convertible
| | | | | Joined: Sep 2013 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2013 Posts: 36 | Bob, Where did you find the new hardware?
Thanks, Chuck | | | | | Joined: Sep 2013 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2013 Posts: 36 | | | |
