5 members (rfs56trk, Maybellene, klhansen, greenie-reddy, stlcardinalsguy), 102 guests, and 2 robots.
Topics128,034
Posts1,055,542
Members48,425
#1130334 10/20/2015 3:03 AM
would a 1962 chevy car or truck 235 came in chevy orange? just picked up a 59 with this engine in it and it is orange.......
thanks in advance.
1949 Dodge Coronet
1955 2nd Chevy 4400 1.5 ton
1955 2nd Chevy 3100 1/2 ton
1957 Chevy 5400 LCF 2 ton
1966 Dodge D100 Sweptline
1968 Chevy P20 stepvan
1969 GMC LWB pickup
1972 GMC Sprint
1974 CP30 shorty bus
Materman #1130341 10/20/2015 3:30 AM
No. Only Passenger V8s and the Chevy II/Nova 153 4 cylinder and 194 6 cylinder were orange. A Passenger 235 would be blue, and the Truck version would blue/gray.
Bill Burmeister
Materman #1130349 10/20/2015 4:24 AM
Chevy orange was readily available in engine shops. It might have been used on any rebuilt engine.
What is the code that is pressed into the block just behind the distributor?
That is the Engine Serial Number and it might help to ID the engine (car or truck, and model/series of vehicle).
How did you ID the year - 1962?
Depending on the year, the truck high-pressure 235 might have been gray, blue gray, or even green (supposedly).
Materman #1130423 10/20/2015 4:01 PM
the numbers stamped behind the dizzy are F0922J (I believe it is a zero, but could be an O in the number) and how I came to the conclusion that is a 62 235 is there are no captain's bars above the starter to indicate a 261 and the front mount is under the crank pulley/balancer and there are no side mounts cast into the block.
1949 Dodge Coronet
1969 GMC LWB pickup
1972 GMC Sprint
Materman #1130427 10/20/2015 4:27 PM
As you most likely know:
F 0922 J
F = Flint, M
09 = September
22 = 22nd
J = 3100 = 235 engine (J was used from 1957 to 1962)
If you want to ID the years, post the head and block date casting codes (you might have done this already - if so, sorry).
