6 members (tclederman, Peggy M, MRMEROTH11, Wickedbass, Barney1951, TUTS 59), 78 guests, and 1 robot.
Topics128,068
Posts1,055,880
Members48,428
Looking for a source for the frame wiring clips that go from the front of the cab to the rear along the frame rail part# 52-925 1941-1959 GM trucks. Classic Parts shows them, but they have been on back order since 8/30/2015! Found out today that there supplier doesn't know when they will produce again! Any idea where else I could get these clips?
Tim
1970 VW Beetle
Tim
I checked out Rhode Island Wiring Service and YNZ and neither of them show them in their catalogs. You might want to consider those used on the Model A Fords as they are very similar to the frame rail clips used on our trucks. wiring frame clips
Mike
You might try inlinetube.com. They have a lot of that type of thing.
Dennis
40 Chevy 1/2 ton
Tim/Mike,
Can you post a link to a photo of the GM clip?
Restoration Specialties might have it - listed in their GM section.
My 1954 clips do/did not look like the one posted by Mike. Where/how did those clips attach to the frame?
check these folks maybe they have matching
http://www.clipsandfasteners.com/Clips_s/219.htm
Baking in the nice desert sun, breathing life back into a 48 3800 5 window.
Tim,
Here is a photo from Classic Parts of the clips I'm looking for: http://i1290.photobucket.com/albums/b528/atldoverde_58/frame%20clip_zpschxu5orx.jpg
Tim
1970 VW Beetle
Chevs of 40s - wire harness clips
Jim Carter probably has them - good luck searching for them.
Tim,
Already checked with Jim Carter. They only have the under hood clips. Chevy's of the 40's has them, but the shipping is outrageous! I'll keep looking.
Tim
1970 VW Beetle
Gas Pumper
Gas Pumper
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
Tim
The clip you pictured goes through a hole in sheet metal and does not clip on the frame rail. I'll see if I can find one on my 1950 Chevy to photograph.
Mike
Thanks, Mike,
Gas Pumper
Gas Pumper
The ones I posted earlier are found on the frame rails to hold wiring in place. I guess it was cheaper to just drill the holes and stick these things in place. They are also found on Harrison Heaters to hold the wires in place.
Deve
The Think Tank
Huck,
What was left of the frame clips I pulled from my '49 were pushed through the holes in the frame. Not sheet metal. If you look at the part number from Classic Parts you'll see what I'm talking about.
Deve,
Those are the clips for the firewall and inner fender. Thank you for the input.
Tim
1970 VW Beetle
Gas Pumper
Gas Pumper
Tim what is the difference in them? I have taken hundreds of these things off trucks over the years and never noticed a difference between the frame, firewall and inner fenders. Good luck and let us know where you got the ones you are looking for.
Deve
The Think Tank
I don't have access to it now, but I recall that the FAM had pictures of the different style of clips and where they were used including some that clipped onto the frame rail and not into a hole.
Mike
I appreciate all the input I have gotten from Tim, Mike and Deve concerning the frame rail wire harness clips. I could use another style clip, but I was trying to replace these with the same type of clips I removed. If all else fails, I guess I will just have to go that route.
Thanks again for the info and suggestions!!
Tim
1970 VW Beetle
Gas Pumper
Gas Pumper
Here are some of the clips I saved when tearing down trucks over the years. Are the clips you are looking for here? How many do you need?
Wire Clips 1
Wire Clips 2
Wire Clips 3
Wire Clips 4
Wire Clips 5
Wire Clips 6
Wire Clips 7
Deve,
Thank you for offering the frame rail clips. I found a set. It seems these clips were used from 1941-1965 on all GM truck and cars for the wiring harness that ran to the tail lamps. Had to purchase through a Corvette parts house. A little pricey but now I've got a set coming.
Thanks again for your generous offer.
Tim
1970 VW Beetle
Tim, I have been following your progress with your rebuild one piece at a time with all of your different questions about specific correctness.
I am torn between,
1)Looking forward to seeing pictures of it when you are done.
2)Not looking forward to seeing pictures of it, lest it makes me sick because it will be too much for me to live up to with my rebuild.
I guess I will have to deal with it one way or the other.
Carl
Carl,
I really appreciate the words of encouragement! I will tell you this....My '49 is not completely correct as it was delivered in 1949, but I am doing my best to get it there. I'm sure a lot is not correct, but I'm pleased with it so far. When I get it completed I will send you photos. Just keep in mind we all "put lipstick on a pig" to make it look good when we have limited information from 65+ years ago.
Thanks again.
Tim
1970 VW Beetle
Tim,
Only source for the original that I know of is an old parts truck.
This is what you are looking for.
Frame Wire Clips
Harold
Harold
Carl,
Just came across this source for the clips.
Harold
Wire Clips
Harold
Tim,
Just came across this site. The clips look very much like the ones on our trucks.
Harold
Wire Clips
Harold
