BUSY BOLTERS Are you one? The Shop Area
| | Click on image for the lowdown.
1 members (Joe W),
544
robot. | Key: Admin,
Mod | | Forums66 Topics126,777 Posts1,039,270 Members48,100 | Most Online2,175 Jul 21st, 2025 | |
#11295 12/14/2002 5:45 AM | Joined: Nov 2002 Posts: 394 'Bolter | 'Bolter Joined: Nov 2002 Posts: 394 | About a week ago I'd poured 5 qts. of oil in my 235 6 cyl. chevy. My problem is it's not even showing on the dipstick.Yes, I made sure the drain plug was in. This engine has never run before and I'm wondering if I've even have the correct dipstick and tube.Could I get one you guys to measure the lenght of the stick, and tube where it starts from the block. I understand it willtake 6 qts. with a filter correct? THANKS.  | | |
#11296 12/14/2002 7:43 AM | Joined: Dec 2001 Posts: 1,745 Member | Member Joined: Dec 2001 Posts: 1,745 | It takes more than 5 quarts
54 3100 with 235 62 flatbed dump C60 with 261
#11297 12/14/2002 8:02 AM | Joined: Jul 2002 Posts: 68 Member | Member Joined: Jul 2002 Posts: 68 |
'54 3100-235-T5 trans-12 bolt 3:31 '68 Impala 307/350 '78 Sportster/Original owner
#11298 12/14/2002 10:41 AM | Joined: Feb 2001 Posts: 1,897 Member | Member Joined: Feb 2001 Posts: 1,897 | It still should show on the dipstick with 5 quarts IF the stick is correct.
#11299 12/14/2002 8:42 PM | Joined: Aug 2001 Posts: 139 Member | Member Joined: Aug 2001 Posts: 139 | ol'55, I don't know if they made different sizes of oil pans for the 235. I would make sure about that. If the pan you have is the same size I'd check the dipstick to see if it's the same length. Some thing is off, the pan size or dipstick length. Like someone said, it should show on the stick with 5 quarts in the pan. Some one here will be able to give you the length your stick should be. And also probably the out side deminsons of what your oil pan should be. Good luck. Mike | | |
#11300 12/14/2002 10:16 PM | Joined: Jan 2001 Posts: 46 Wrench Fetcher | Wrench Fetcher Joined: Jan 2001 Posts: 46 | On my 235, the dipstick tube is 6 inches long from the block to top. The dipstick length from the top of the tube to the tip is 15 3/8 inches. The full mark is 13 1/2 inches from the top of the tube. I hope this is of some help to you.
I also think I should change my oil - kinda dirty. | | |
#11301 12/15/2002 12:17 AM | Joined: May 2001 Posts: 1,878 'Bolter | 'Bolter Joined: May 2001 Posts: 1,878 | My dipstick from a '53 235 is basically the same as Frets. It is 15 1/8 in. from the stop to the pointy end and 13 5/16 in. from the stop to the full mark. It holds 6 qt. with the filter. 1948 3/4-Ton 5-Window Flatbed Chevrolet 33 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
#11302 12/15/2002 5:29 AM | Joined: Nov 2002 Posts: 394 'Bolter | 'Bolter Joined: Nov 2002 Posts: 394 | Well I believe I have found my problem here thanks to you amigos. I rechecked my tube and dipstick and I am showing 6.50" on the tube from the block to the top and the stick is only 9.00" long. DA DA no wonder I don't see any oil.I'm about to start the engine and with no oil on the stick I said ah ah.. I'm wondering how the other guy read it, before me? Any way guess I'll go looking for a tube and stick. THANKS AGAIN GANG OL'55.. :p | | |
#11303 12/15/2002 6:37 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | 'Bolter Joined: Jun 2000 Posts: 2,773 | If you want to run the engine, drain all of the oil out and put in 5 quarts, 6 if you have a filter.
Fred 52 3600 69 C-10
#11304 12/15/2002 5:00 PM | Joined: Dec 2001 Posts: 1,745 Member | Member Joined: Dec 2001 Posts: 1,745 | If you think about it we should all go and check our sticks...
Imagine running with a couple of quarts too many. It would be easy for a stick to get changed or broken in all those years.
#11305 12/16/2002 4:07 PM | Joined: Jul 2000 Posts: 962 Shop Shark | Shop Shark Joined: Jul 2000 Posts: 962 | I ran into this when building my 235. There were at least 3 different pan styles, and 3 different oil pump pickups to match. I'm running a '60 block with a '57 oilpan and pickup, with a '54 dipstick. I had to move/bend the dipstick tube a little to clear the oil pump pickup tube. Now my engine reads full with 5 quarts, no filter.
good luck
chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
