3 members (Otto Skorzeny, Shaffer's1950, 1 invisible), 164 guests, and 5 robots.
Topics128,088
Posts1,056,122
Members48,435
#112989 09/24/2003 4:20 AM
Does anyone know of a good way I can restore this back to factory spec?
[img]http://bradandcharlottes.com/68/radio.jpg[/img]
#112990 09/24/2003 12:33 PM
Find a wrecked truck and cut as much out as you can for a patch panel,weld it in yours,thats probably the best way.
#112991 09/24/2003 1:26 PM
k10 Offline
There are patch panels available for other year Chevy trucks. With so much out there, I'm surprised that one wouldn't be available for the 67-72 trucks. Try Jim Carter's and the rest. GMCPaul used to have a bunch of this stuff too.
#112992 09/29/2003 4:31 AM
I tried looking up jim carters catalog and had no luck can you post a link?
#112993 09/29/2003 5:20 AM
I found it. Didnt see it on the website so I sent him a email. If he doesnt have anything then I will head to a boneyard with a cutting torch and cut one out.
#112994 09/29/2003 7:56 AM
Where are you located?
#112995 09/29/2003 5:32 PM
San Jose Calif.
#112996 09/29/2003 5:58 PM
I would MIG weld a panel to fill in that hole. Not sure about the wood grain vinyl though.
#112997 09/30/2003 12:49 AM
That wood grain piece is bolted in. Has some bolts that will come right out. The previous owner had a new style radio in there.
