| | | Forums66 Topics128,127 Posts1,056,357 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2002 Posts: 142 Member | | Member Joined: Apr 2002 Posts: 142 | Find a wrecked truck and cut as much out as you can for a patch panel,weld it in yours,thats probably the best way. | | | | | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | There are patch panels available for other year Chevy trucks. With so much out there, I'm surprised that one wouldn't be available for the 67-72 trucks. Try Jim Carter's and the rest. GMCPaul used to have a bunch of this stuff too. | | | | | Joined: Sep 2003 Posts: 82 Member | | Member Joined: Sep 2003 Posts: 82 | I tried looking up jim carters catalog and had no luck can you post a link?
Thanks | | | | | Joined: Sep 2003 Posts: 82 Member | | Member Joined: Sep 2003 Posts: 82 | I found it. Didnt see it on the website so I sent him a email. If he doesnt have anything then I will head to a boneyard with a cutting torch and cut one out. | | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 |
| | | | | Joined: Sep 2003 Posts: 82 Member | | Member Joined: Sep 2003 Posts: 82 | | | | | | Joined: Aug 2003 Posts: 264 Member | | Member Joined: Aug 2003 Posts: 264 | I would MIG weld a panel to fill in that hole. Not sure about the wood grain vinyl though. | | | | | Joined: Sep 2003 Posts: 82 Member | | Member Joined: Sep 2003 Posts: 82 | That wood grain piece is bolted in. Has some bolts that will come right out. The previous owner had a new style radio in there. | | |
