Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
7 members (Wickedbass, Wally / Montana, TexasA&M48Truck, FAST55, Chester2392, JW51, 68ironhead), 50 guests, and 4 robots.
Topics128,010
Posts1,055,298
Members48,419
#1129680 10/15/2015 11:29 PM
I Have a 1950 3600 with a 283 and an open drive line sm420 4 speed. I have moved the engine/trans forward @ 1.5 inches, and I am making a mount for the drive shaft support bearing and trying to figure out how high/low within the frame to place it.
Does anyone know if there is supposed to be a specified angle of the front half of drive shaft or is it supposed to be in line with the center line of the engine?
Tim
Tim
1950 3600 Some Pictures
1951 3100
1952 3100 Some Pictures
It really doesn't make any difference. We used to have to move driveshaft center support bearings off to the side to accommodate a pneumatic blower. It is more common to mount the center bearing up near engine level. However, you do need some offset. A drivehsft needs some offset for for the needles to have to move. If there is no offset, the needles will not move and wear into the cross in a hurry.
Check page 13-15 here
http://www2.dana.com/pdf/J3311-1-HVTSS.PDF
Bacically as a rule of thumb, your rearend needs to be the same angle as your center or 1st driveshaft.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
