7 members (2-Ton, 55shaker, cmayna, Hotrod Lincoln, CuzzFuzz, jmoore, Bill Hanlon),
49
Mod | | | Forums66 Topics128,018 Posts1,055,259 Members48,417 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Here are the particulars. 350, 700R4, Edlebrock 1400 series(not sure of exact #). Back many years (40+) I use to be fairly good at adjusting carbs using the Tach. Turn the screws in until rpm dropped then back out until stable. Back and forth with each screw until satisfied. Here is the problem. With this carb I can screw each one all the way in without any drop in rpm. Idle is at 600 no vac lines plugged off, just hooked where they should go. What has my fading memory forgotten? Can these newer carbs even be adjusted the old way? BTW, the '48 runs ok and starts right up without problems, just running too rich.
| | | | | Joined: Sep 2015 Posts: 6 New Guy | | New Guy Joined: Sep 2015 Posts: 6 | couple of reasons that can happen --float level too high or fuel leaking around internal gaskets or the leak at power valve -use to work on all those carbs and still working on carbs -- soon carbs will get all eaten by alcohol-Beck's- | | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | Disconnect and plug the vacuum line to the distributor. If that doesn't help, you either have a vacuum leak somewhere or an internal carb issue. Carl
| | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | 216chevy, no alcohol/ethanol anywhere near my vehicles, ever! Good possibilities for problems though.
Carl, BC52, kinda what I thought. Just hate the thought of tearing into the internals. Its been a long time since I did one.
Keep the ideas flowing folks.
| | | | | Joined: Dec 2008 Posts: 898 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 898 | Partially choke the carb with your hand. If the RPM raises that would be a good indication of a vacuum leak.
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Aug 2013 Posts: 217 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 217 | The Pontiac 400 engine in my 55 2nd truck, with Edelbrock #1405 carb, was running rich, and I suspected high fuel pressure. I installed a fuel pressure gauge and found I had 10.5 lbs pressure. Put in a fuel regulator and brought pressure down to 5 lbs. Took care of the problem. | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | fuel pressure regulator set at 5psi already. I'll try the above suggestions.
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Guess it must be internal. Short of tearing it down I've followed all the listed suggestions. Two choices, tear it down to put a kit in it or switch to a Holley.
| | | | | Joined: Nov 2002 Posts: 2,763 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,763 | Guess it must be internal. Short of tearing it down I've followed all the listed suggestions. Two choices, tear it down to put a kit in it or switch to a Holley. What is the footprint of the intake? If squarebore, another option would be Carter 9625s or 9635s (NOT 9635sa). If spreadbore and the e-clone is mounted on an adapter, other options would include a late 1960's or early 1970's Rochester Q-Jet for Chevy 350 OR a Carter TQ 9800s or 9810s. The e-clones are vacuum-cast (genuine Carters were pressure-cast). The e-clones have had porosity issues. Possibly, this is your problem. Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Feb 2010 Posts: 129 Shop Shark | | Shop Shark Joined: Feb 2010 Posts: 129 | I wonder if you have the throttle screw turned up too high, so it's running like it would if you had your foot on the gas a little. That can make the mixture screw seem to not work right.
Ed Miller '58 Apache short Fleetside half ton Napco Falls City, OR
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | 600rpm, square bore no adaptor.m
Thanks Carbking I did not know about the porosity situation. I already have a Holley I could put on. May search for a Carter.
