2 members (Jon G, Otto Skorzeny), 203 guests, and 2 robots.
Topics128,080
Posts1,056,063
Members48,433
Just wondering if I can use my 6v starter on 12 volts, a neighbor of mine said it would work just fine, just spin a lil faster and start up quicker!?? It is on a 216 6L, 1940 big bolt. Thanks!
BJ
'Keep on Truckin'
1940 1.5 ton dump
Welcome to the 'bolt,
6V starter will work fine in a 12V system, many successful examples including my own truck. A 12V starter will not properly fit a 6V engine (see here and read the 9th post down from tclederman. He explains the tooth count difference between 6V and 12V applications.)
It does spin faster, be careful about cranking it too long if you're having trouble getting the truck started.
Have fun,
1947 3100 Advanced Design
Never, never, never, never give up. - Churchill
The faster spinning 6 volt starter is one of the best advantages of the 12 volt conversion. Quick start up!
Carl
Ex Hall Monitor
Ex Hall Monitor
Unless you're wanting to run a high power stereo there's no good reason to "upgrade" to 12v. A 6v system with a good battery & starter with clean connections & properly sized cables will start just fine. Having said that back to your original post, if you don't crank for extended periods your starter will be just fine.
Thanks guys, just reconfirms my thoughts for the conversion!
BJ
'Keep on Truckin'
1940 1.5 ton dump
is there a such thing as 12v points, condenser and coil that need to be installed before attempting to use a 12v battery? I have no other wires connected to this engine besides the starter connection to the battery and power to the coil for a test fire.
1951 Chevy 3100 1/2-Ton
"Piecing it Together - Blow by Blow"
Follow in the DITY
More photos in Flickr
1939 Chevy 3/4-Ton
In the Project Journals Forum
points - same 6v and 12v
condenser - same 6v and 12v
coil - different 6v and 12v
information obtained from Rockauto.com on-line catalog
Note: 12v ignition system needs a ballast resistor in-line to the coil, unless the coil has an internal resistor.
Thanks for the quick reply!
Does the ballast resister element only apply if the generator is hooked up? Also, how much resistance is necessary? 3 Ohms?
Follow in the DITY
1939 Chevy 3/4-Ton
Ballast Resistor helps control current at the points. Generator/Alternator, makes no difference. Balance Ohms to the coil. You want to see about, 4 to 6 volts across the Ballast resistor. Just put a meter across the Resistor with the points closed, and the Ignition on. Don't leave the ignition for very long. You will get to recharge the battery, and maybe replace the points.
Steve H
Perfect, thanks!
Follow in the DITY
1939 Chevy 3/4-Ton
V
VEW Offline
V Offline
On topic question....I think.
It doesn't matter which way current flows through the resistor, does it?
I'm getting 12v in and 12v out, so just wondering???
~ Victor
1957 3100 - moved on
It doesn't matter; [basic/simple] resistors like the ignition resistor work the same in "both directions".
Have fun.
The only time the resistor will show a voltage drop is with the points closed and the ignition on. If the points are open, you'll see 12V on both ends of the resistor. With the engine running you'll see battery voltage at the upstream end of the ballast resistor and 9-10 volts at the coil + terminal, if everything is wired correctly.
V
VEW Offline
V Offline
Thank you gentlemen.
~ Victor
