7 members (Gray_Ghost, Rusty Heaps, Brian Moore, 55shaker, Otto Skorzeny, Hotrod Lincoln, 1 invisible),
85
Mod | | | Forums66 Topics128,028 Posts1,055,414 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2015 Posts: 58 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2015 Posts: 58 | Hey everyone. The cab on my 48' is all rusted out, so I thought a good fix would be to swap the cab for a less rusted or rust free cab. My question is, are the cabs different for the different size trucks, like 1/2 ton and 2 ton? | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | No, same size.
One difference is 48 model has a center rear cab mount. The later cabs have one mount each side of the frame at the rear of the cab. This is not a problem at all, but you may need to drill 4 holes in the frame to use the later type (better) mount system.
Another advantage to using a later cab is the gas tank will be in the cab, so with your original you'd have two tanks, twice the range.
Grigg | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | | | |
