7 members (fonz8261, Rexville48, 1955 1 Series, Peggy M, mk72, Shardean, 55shaker),
60
Mod | | | Forums66 Topics128,022 Posts1,055,387 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | I've painted a couple of cars (OK, 1 twice) several years ago. I used PPG Acrylic Lacquer. I was thinking of doing the same with the truck, but seems PPG doesn't have that anymore. At least I couldn't see it at their site. I'm looking for something I can do myself without a fresh air system, if that's doable. I have the mask with 2 filters from the last job. What are you guys using?
40 Chevy 1/2 ton
| | | | | Joined: Jul 2002 Posts: 46 Member | | Member Joined: Jul 2002 Posts: 46 | If you don’t want to use a fresh are supply mask use the ppg or Dupont paints that do not contain isocyanates. most paints on the market today are iso free but you should still were a mask with a pre-filter and a charcoal filter
DUSTY G.
you can do anything you want as long as you have an O [censored] man in case you mess up
| | | | | Joined: Oct 2000 Posts: 804 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 804 | Dusty, I don't know of a single ISO free paint or clear on the market right now. There have been ones almost every company has tried, but they have all dropped them as far as I know. ANYTHING with a hardener outside of epoxies and primers that specifically say ISO FREE on them are going to have ISOs.
I am sure that Sikkens, Glasuit or some one of the other European brands has something available. And the big boys like PPG and the like are trying once again to offer one, but as of right now I know of none.
For the home hobbiest that is doing a paint job now and then, first of all I say invest the $400.00 or so and get a "Hobby air" available at autobodystore.com. But if you are NOT going to do that study the use of the charcoal resperator and you will find that the OSHA requirments for the fresh air system have much to do with the proper use of the charcoal mask, not whether it filters out ISOs or not. DO YOUR HOME WORK
1948 Chevy Pickup Chopped and sectioned owned since 1974 when I was 15.
| | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | Martinsr , that was dustyG ,  . I didn't know that about the isocyanates either , thanks for the heads up . | | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Well, yeah. I'm about talked into a fresh air system. Problem is I'm just trying to get a pair of rear fenders in primer state so I can get them back on the truck. I'm thinking I can prime with a sealer to keep the moisture out then work other areas from time to time the same way. By next summer I should be ready to reprime and top coat. I was thinking today of maybe just having a local shop prime/seal the fenders and get them pupies back on!
40 Chevy 1/2 ton
| | | | | Joined: Jul 2002 Posts: 46 Member | | Member Joined: Jul 2002 Posts: 46 | dupont carrys a number of iso free paints and under costs these include Iso free under coats are 615S/616S & 2500S series sealer. Productive products are 4000S series and 4904S and 4910S, 4940S, 4970S
DUSTY G.
| | | | | Joined: Oct 2000 Posts: 804 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 804 | Does DuPont offer an ISO free paint line? The ones you posted are undercoats. The strange thing is DuPont doesn't have the ISO free in the name of these primers and sealers, strange. How do you know they are ISO free? The DuPont web site is not up to par with others and doesn't have an MSDS catalog on it.
| | | | | Joined: Jan 2001 Posts: 47 Member | | Member Joined: Jan 2001 Posts: 47 | Martin
Is laquer available any where? My suppliers down here all say it isn't made any more. Thanks | | | | | Joined: Oct 2000 Posts: 804 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 804 | Yes it is made Judd, it is still in my Sherwin Williams price sheets. If you are in a VOC regulated area, you can forget it. If you are in the "national rule" for VOC it is legal for use on a vehicle that was originally painted in lacquer. If can be found though I am sure it is getting harder by the minute.
| | | | | Joined: Jul 2002 Posts: 46 Member | | Member Joined: Jul 2002 Posts: 46 | iso free single stage is the Cronar product. The iso free clear is 1780S. Basecoats do not have iso's in them unless you add the 12305S which is not necessary in the Chromabase system. Product sheets and information can be found on our web site at www.performancecoatings.dupont.com
DUSTY G.
| | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | OK. I ordered a FinishLine II today and Hobby Air unit tomorrow. So now I need to decide which paint system would be best. This is a driver not a show truck. I'm also thinking I want a solid color, not metalic. Any suggestions? Oh, and I'll be painting in the garage. Plan is to fix/primer-sealer area by area until next summer then reprime and finish it.
40 Chevy 1/2 ton
| | | | | Joined: Jul 2002 Posts: 46 Member | | Member Joined: Jul 2002 Posts: 46 | first of all is your garage attached to the house second is there any open flames I.e. gas furnish or water heater if so dont even think about paintting in your garage
DUSTY G.
