| | | Forums66 Topics128,036 Posts1,055,461 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 18 'Bolter | | 'Bolter Joined: Mar 2006 Posts: 18 | 55.1 truck with a 327. Looking for a clean way to add the throttle linkage. Is there a kit somewhere that works easily? | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I suppose you can fab one up but I bit the bullet and bought an after market that had the foot pedal, wire and connectors. With the 327 you should be able to mount the gas pedal and pretty much come out in a straight line to the carb. I think mine was made by Lokar.....or maybe I bought the linkage as a package and then the gas pedal of choice. Still, not a bad job. Clean and neat looking. | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | Has anyone used a Task Force pedal/linkage which came on V8 trucks?
| | | | | Joined: Dec 2013 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2013 Posts: 54 | I used the TF v8 style firewall linkage (pivot?) on my AD. The contour of one of the mounting points doesn't match up with the my firewall very well, but can be made to work. I haven't put a pedal on as of yet.
Tim | | | | | Joined: Apr 2015 Posts: 336 Shop Shark | | Shop Shark Joined: Apr 2015 Posts: 336 | When I replaced my 6 cyl with a V8 in my '59 Apache truck, I installed an original V8 throttle linkage. It hooked up with no issues and seems to work just fine. Heck, the holes for the bolts were already there. I used my original gas pedal also. I have an extra that I'll sell, it needs sand blasting and painted and the hardware.
1959 3100 Apache Fleetside
| | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | I used the TF V-8 throttle kit in a 1950 I put a 350 in. Had to modify the short rod that goes through the floor the just a little, but works nice. | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | Roy, where did you get the kit? Was it a straight up TF part, or was it designed for an AD? Carl
| | | | | Joined: Apr 2015 Posts: 336 Shop Shark | | Shop Shark Joined: Apr 2015 Posts: 336 | Carl, The linkage I put in my truck came off a 1956 1 ton truck with a 265 in it. The spare I have came off a 1959 3600 with a 283,
