4 members (tclederman, FAST55, JW51, 1 invisible),
88
Mod | | | Forums66 Topics128,269 Posts1,058,398 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2002 Posts: 154 'Bolter | | 'Bolter Joined: Aug 2002 Posts: 154 | Could someone tell me the difference between these 2 heads?? 3835913 vs 3836848. Do they have same size valves? Why does the 3836848 have higher compression ratings? I saw some old posts and someone said they were basically the same head except for the water temp gauge. I have both heads, just trying to figure out which is the better head. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Eric,
My guess is that any difference in valves might explain only a little of the difference. There must be a smaller volume chamber in the "848" head.
A few months ago, someone posted that they might try to measure the combustion chamber volumes of different 235 heads.
If you want high compression, the "848" head is better than the "913" head. | | | | | Joined: Dec 2008 Posts: 1,923 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,923 | Except for the 1950-52 Powerglide head, all 235 & 261 heads have 1.875" intake, 1.500" exhaust. | | | | | Joined: Aug 2002 Posts: 154 'Bolter | | 'Bolter Joined: Aug 2002 Posts: 154 | I just got the 848 head on a spare motor, The 913 is on motor in the truck and running. The truck is going to be a retirement and week end toy. How much of a gain can be expected from the 848 head,gas mileage, performance, power ect... Is it worth changing heads or just keep it for a spare? | | | | | Joined: Feb 2004 Posts: 29,947 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,947 | Unless you're planning on other modifications like a hotter cam, intake/exhaust changes, etc., I'd recommend staying with the original head. Stovebolt cylinder heads are notorious for having cracks, so it's possible the 848 that hasn't run in a while might not be serviceable when you're partway through the swap. If you do go ahead with it, have a machine shop do a valve job and inspect it for cracks first. Jerry
