2 members (78buckshot, NJC),
99
Mod | | | Forums66 Topics128,149 Posts1,056,819 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2015 Posts: 89 Shop Shark | | Shop Shark Joined: Sep 2015 Posts: 89 | I havent pulled my cab off yet but I plan on it in the next couple of weeks. I've noticed some pieces of folded over rubber between some cab mounts and some pieces of wood. does this kit on ebay look right for cab mounting hardware? or does this have a bunch of extra things i wouldnt need for a 2-ton? http://www.ebay.com/itm/1939-1940-1...19257901?hash=item419dbc9c2d&vxp=mtrdoes anyone use some sort of rubber instead of wood or is wood still the best option?
1946 Chevrolet 2-ton
| | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | That kit looks correct, but do you need all that hardware? Before ordering that expensive item, see if you can reuse the existing hardware. I think the original cushioning material is a heavy rubberized fabric of some sort. You might be able to find a replacement material or reuse what is there. Kent | | | | | Joined: Sep 2015 Posts: 89 Shop Shark | | Shop Shark Joined: Sep 2015 Posts: 89 | i believe i have all the hardware, i'll look for a kit that just has the rubber then, if i dont break all the bolts taking them apart!! Thanks for the reply! I'll be taking my cab off probably this weekend so I'll know if my cab bolts and hardware are any good, taking the fenders and runningboards off i ended up breaking or having to torch off most of the fastners!!
