2 members (klhansen, 1 invisible),
107
Mod | | | Forums66 Topics128,119 Posts1,056,648 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,836 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,836 | What do the cam lobes look like? You can install new lifters on an old cam- - - -just do the same break-in procedure you would use with a new cam, 15-20 minutes at high idle (1500-2K RPM on initial startup) to let the lifters wear-in to the cam. If the cam lobes are showing noticeable wear or rust pits, swap the cam also.
Those are solid lifters- - - -no doubt about it. Jerry
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | You will need to inspect the cam.
I have limited experiences with came (three rebuilds), but if there are no pits in the cam-lobes to lifters mating surfaces, I'd probably reuse the cam.
If you break down the engine (you posted that you hoped not to break it down), you'd get a better look all cam-wear surfaces. | | | | | Joined: Sep 2015 Posts: 89 Shop Shark | | Shop Shark Joined: Sep 2015 Posts: 89 | Im going to re measure my clinders tonight and take a look at the camshaft (while its still in the motor)
I was looking for those milkcan lifters online and boy are they expensive, probably $40 a piece with shipping!
Is there another lifter that will work? i was going to buy new pushrods anyways since one was bent, what would my options be if my camshaft is good and looking for replacement lifters and rods?
1946 Chevrolet 2-ton
| | | | | Joined: Feb 2004 Posts: 29,836 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,836 | There's a set of 12 brand new ones on Ebay for $109.00 plus shipping:
http://www.ebay.com/itm/12-Mechanical-Valve-Lifters-53-54-55-Corvette-235-NEW-/191718184306?fits=Make%3AChevrolet&hash=item2ca34b5572:m:mE-s_-VJOxI9GTFrrlmLWCQ&vxp=mtr
| | | | | Joined: Sep 2015 Posts: 89 Shop Shark | | Shop Shark Joined: Sep 2015 Posts: 89 | Cam loves all looked pretty good to smooth and shiny. Rechecked bore as carefully as I could, 1st number is top of cylinder 2nd is 1/2 way down #3 and #4 were the super dirty Pistons and combustion chambers 1- 3.812. 3.809
2- 3.815. 3.809
3-3.810. 3.813
4-3.811. 3.812
5-3.815. 3.809
6-3.815. 3.809
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Well Carl, I'm gonna have to eat my words for breakfast this morning when it comes to a bent push rod. Don't know where my head was, probably way back in time somewhere in a SBC. The picture I had in my head was of a tubular push rod and since it's been several years since I've had the side cover off a Stovebolt, I'd completely forgotten that the solid lifter push rods were a solid forged pushrod. The one bent rod in my 261 has a slight wow in it. In fact you don't really notice it when it's laying next to the other ones and you have to roll it to to pick it out from the rest. Can it be straightened, yep, I agree with you now. If you can straighten a crank or cam then I'm sure you could get away with straightening the pushrod, that is, as long as it's just a wow and not actually a sharp bend. So, lets just see if we can get 21,000 out of this one also.
dg
Denny G Sandwich, IL
| | | | | Joined: Feb 2004 Posts: 29,836 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,836 | Those bore measurements look pretty good for a re-ring job. The crank needs a little polishing, but as long as you don't take much off of the diameter and it's round within .001" or so you should be good to go. I like to use a long 320 grit piece of emery cloth and a "shoeshine" motion to polish the crank journals, followed by a very thorough cleanup with solvent and compressed air. If the crank is out of the block, you might try getting a machine shop that regrinds crankshafts to power-polish it. I'm seriously considering making my own crank polisher with square tubing, a retired Skilsaw motor and some home-brewed ball bearing sanding belt guides. The crank gets mounted in a lathe and turned slowly, and the belt sander is used to polish the journals. Jerry
| | | | | Joined: Mar 2010 Posts: 10,294 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,294 | Well Carl, I'm gonna have to eat my words for breakfast this morning when it comes to a bent push rod. Don't know where my head was, probably way back in time somewhere in a SBC. The picture I had in my head was of a tubular push rod and since it's been several years since I've had the side cover off a Stovebolt, I'd completely forgotten that the solid lifter push rods were a solid forged pushrod. The one bent rod in my 261 has a slight wow in it. In fact you don't really notice it when it's laying next to the other ones and you have to roll it to to pick it out from the rest. Can it be straightened, yep, I agree with you now. If you can straighten a crank or cam then I'm sure you could get away with straightening the pushrod, that is, as long as it's just a wow and not actually a sharp bend. So, lets just see if we can get 21,000 out of this one also.
dg Good on you DG! The only thing more honorable than one being right all of the time, is one's ability to admit when they are not. Carl
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ....the local crankshaft guy, been in business over 20years, polished my 261 crank for $30. I thought it was well worth it since I don't plan to polish many more in this life.... | | | | | Joined: Sep 2015 Posts: 89 Shop Shark | | Shop Shark Joined: Sep 2015 Posts: 89 | what shop manual would i want if i attempt a rebuild for this 1955 261?
| | | | | Joined: Jul 2007 Posts: 444 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 444 | Here's a full set of ( 12 ) GM NOS solid lifters for your engine. ebay photo shows these rare lifters to be in excellent like new condition. These don't show up on ebay very often I'd grab them up ASAP ! photo @ photobucket http://i669.photobucket.com/albums/vv57/glp0329/3836342/GM_3836342_GM_NOS__zpskclqpq8d.jpgebay link: http://www.ebay.com/itm/GM-3836342-Valve-Tappet-Assembley-N-O-S-/131575000306?hash=item1ea27b2cf2:g:~iMAAOSwT6pVx9OY&vxp=mtr @ $55.00 & $12.00 shipping = $67.00 that's less than $6.00 each for GM NOS lifters with shipping. Now that's a bargain ! Ya snooze.......Ya lose
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | what shop manual would i want if i attempt a rebuild for this 1955 261? Probably the 1954 Shop Manual. There is also a 1955-1st series supplement. If your water pump body is entirely below the head, use the 1955 Truck Shop Manual. | | | | | Joined: Sep 2015 Posts: 89 Shop Shark | | Shop Shark Joined: Sep 2015 Posts: 89 | Thanks guys, I'm going to talk with a friends dad who knows a lot about engines and have him take a look at it...if he says it looks good for a rebuild I think I'm going to attempt to rebuild the motor, hopefully just a cleaning and magnaflux from the machine shop.
| | | | | Joined: Sep 2015 Posts: 89 Shop Shark | | Shop Shark Joined: Sep 2015 Posts: 89 | Just an update if anyone is interested- found some severe pitting from I assume water sitting in the #3 bore, i think the block will need to be machined now. its already 60 over so im not sure where i would get pistons.
I guess i'll keep the motor and maybe rebuild or sell it one day...
I found a 1961 apache 30 for $500 with a 235 in it. I got it running easily and plan on using it in my 46' - ordered a water pump adapter plate and a gasket kit for it.
I think i'll keep the 61 too, i really like it. its in pretty good shape, probably swap out the suspension though and of course i'll need a new motor for it now! it has those 7.00x18 tires that dont appear to be very cheap or easy to find! neat truck though.
| | | | | Joined: Feb 2004 Posts: 29,836 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,836 | If only one cylinder is pitted, put a thinwall sleeve (3/32")in that one hole, and bore it .060" to match the other cylinders. Then re-use the pistons you have. There's no telling how many one-hole sleeve jobs I've done over 40-something years of engine machining. Of course, I've also been given "worn out" race blocks, sleeved all eight holes back to standard bore, and beat my competitors with their own junk! Jerry
| | | | | Joined: Feb 2012 Posts: 506 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 506 |
Larry
| | | | | Joined: Feb 2004 Posts: 29,836 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,836 | Larry, that's how a lot of low-bucks racing teams survive- - - -they recycle stuff the deep-pocket racing teams discard or replace after one season. I got really good at making those "discard" parts show the other racers what the backside of our car looked like!
One of the guys we ran with had a little sign painted on the back of his car - - - -"When the green flag drops the B S stops!"
