Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
0 members (), 147 guests, and 3 robots.
Topics128,283
Posts1,058,519
Members48,490
Rob or anyone: Under the blue overspray and dirt and grease on the firewall is the original white paint. Can anyone tell me what color the white was called? Jim Carter lists Cascade white in his catalog, but I think it is only for 54-55 models.
Truck is going to be painted white again, I'm just curious if the white had a special name.
http://community.webshots.com/photo/58753176/58833494PeYffM
Check this page on Rob's site:
http://www.oldGMCtrucks.com/page0183.html
It appears it was Cascade White from 51 to 54
Murph
...............___
_=======| :p \___
|(.....)_(O)____(....)c
...(O)...............(O)
'49 GMC 3/4 ton
Another suggestion, afu-if you do Rob's tip, you could take the paint sample to a local bodyshop and have it digitally matched! eek They use a special scanner type tool that digitizes the colour, then calculates and spits out a paint match formula on the computer. Then you can have your paint mixed up. They had one of these gizmos at the dealership where I used to work and it matched paint (even complex modern metallics) darn near perfect! Might be worth a shot.
Regards,
Wannabe smile
"Don't expect anything and you'll never be disappointed"
Thanks for the help! Now just have to find the money to pay for the HIGH priced paint.
Thanks again.
