| | | Forums66 Topics128,105 Posts1,056,209 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2014 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2014 Posts: 34 | Hope this is in the right section..
My truck has been apart for so long my memory has not been good to me.
I know the rear of the cab has a shackle mount each side but its the 2 fronts im not sure of. There is a bolt each side going through the floor of the cab but what is used as a packer/spacer under the cab??
Whats it made from and how thick is it??
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Here is a typical kit, rubber is 3/16"-1/4" usually. http://www.classicparts.com/Late-1949-54-Cab-Mount-Kit/productinfo/35%2D111/
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Jul 2014 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2014 Posts: 34 | Thanks for the reply, i think what confused me was in the bag of bits i bagged up i found only 1 square block (timber) about 1 1/2" thick with a hole through which looked like it could be a cab mount. Im guessing its probably a bed mount ( the bed has never been on properly so i suppose only 1 mount was present).
Thanks | | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | Yep, the wooden blocks are bed mounts. | | |
