6 members (John Dlugos, Otto Skorzeny, Gdads51, Oswald, 216wny, 1 invisible), 168 guests, and 3 robots.
Topics128,101
Posts1,056,179
Members48,436
#1128382 10/07/2015 5:55 PM
Hope this is in the right section..
My truck has been apart for so long my memory has not been good to me.
I know the rear of the cab has a shackle mount each side but its the 2 fronts im not sure of. There is a bolt each side going through the floor of the cab but what is used as a packer/spacer under the cab??
Whats it made from and how thick is it??
Here is a typical kit, rubber is 3/16"-1/4" usually.
http://www.classicparts.com/Late-1949-54-Cab-Mount-Kit/productinfo/35%2D111/
Aftermarket
...pic...
...pic...
Thanks for the reply, i think what confused me was in the bag of bits i bagged up i found only 1 square block (timber) about 1 1/2" thick with a hole through which looked like it could be a cab mount. Im guessing its probably a bed mount ( the bed has never been on properly so i suppose only 1 mount was present).
Fox Offline
Yep, the wooden blocks are bed mounts.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
