5 members (Wayne67vert, Otto Skorzeny, dt235sd, Cosmo, Hanks custodian), 85 guests, and 2 robots.
Topics128,059
Posts1,055,825
#1128214 10/06/2015 5:40 PM
Will 235 and 261 heads interchange with one another?
Later 235 and 261, yes. But, which way are you going?
Drew
U
U Offline
A lot more details such as year & casting numbers are needed for anyone to answer.
Brad
Wrench Fetcher, PhD
Using a casting number 848 head on a 261 will result in somewhat higher compression, but some extra coolant passages need to be drilled in the head to match holes in the 261 block. A 261 head would be a drop-on fit on a 235, but the compression would be lower than with a stock head.
That helps a lot. I asked the question for a friend of mine and I'm not sure what year engine he has.
