| | | Forums66 Topics128,060 Posts1,055,831 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2014 Posts: 140 'Bolter | | 'Bolter Joined: Oct 2014 Posts: 140 | Will 235 and 261 heads interchange with one another? | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Later 235 and 261, yes. But, which way are you going?
Drew
| | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | A lot more details such as year & casting numbers are needed for anyone to answer.
Brad Wrench Fetcher, PhD | | | | | Joined: Feb 2004 Posts: 29,774 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,774 | Using a casting number 848 head on a 261 will result in somewhat higher compression, but some extra coolant passages need to be drilled in the head to match holes in the 261 block. A 261 head would be a drop-on fit on a 235, but the compression would be lower than with a stock head. Jerry
| | | | | Joined: Oct 2014 Posts: 140 'Bolter | | 'Bolter Joined: Oct 2014 Posts: 140 | That helps a lot. I asked the question for a friend of mine and I'm not sure what year engine he has. | | |
