| | | Forums66 Topics128,064 Posts1,055,861 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2005 Posts: 408 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 408 | Hey guys been a long time since i last posted. new job and finally got time to work on my 52. I have a fenton intake for dual carbs I want to install but as i look at the original intake and the new intake it looks like the fenton intake will rub up against my shifter levers. Any thoughts?? Paul
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Some people have ground down a clearance on intake manifolds and some have bent the interfering shifting lever from the shift box to gain clearance.
Drew
| | | | | Joined: Oct 2005 Posts: 408 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 408 | Ok Thanks I was going to try and rotate shift lever collar around and readjust the shift levers. I will let you know how it turns out. | | | | | Joined: Oct 2005 Posts: 408 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 408 | OK I give up SOS NEED HELP!! I have the headers in place new intake in place NO WAY are the shifter levers going to clear the intake. Some one said shave the intake for clearance i need 1/2 inch. would cutting the shifter lever and drilling a new hole work. the rod from trans would be at a different angle but will it work?? Paul | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Hang in there Paul.. there are others who have had this problem and resolved it. Perhaps reposting in the HiPo forum just to be sure its being read by the right people? I have a friend who is almost losing it over Fenton Dual Exhaust manifolds. I tell him to take a deep breath and just give it time. Hes doing great! You will too. | | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | Task Force shifter boxes have levers bent in such a way as to avoid contact with their engines, and I believe they are a direct bolt-in on AD trucks. Carl
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Task Force shifter boxes have levers bent in such a way as to avoid contact with their engines, and I believe they are a direct bolt-in on AD trucks. Carl That's only on the V8 trucks. 6 cylinder trucks are straight.
Bill Burmeister | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | We have shortened and lengthened shift levers for whatever reason. Works okay but to keep things moving the same amount move the hole in the lever on the trans the same amount as the one on the column. Be sure to move the brake and clutch pedal through it's full stroke to verify clearance.
Evan
| | | | | Joined: Feb 2004 Posts: 29,774 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,774 | Changing the radius of the arms (shortening) will result in a longer travel of the knob to complete the shift unless you do a corresponding shortening of the levers at the side of the transmission. Rather than re-drilling holes I'd want a VERY good welder to cut a short piece out of the shift arms and weld them back together. The geometry of the column shifter is pretty critical, so "Measure twice/cut once!" Jerry
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Interesting, this is the first time in the ten years that I've been on the forum that I've heard that installing Fenton headers caused a problem with the shift levers. Surprising since the shifter box is about 7" away from the outside of the header.
dg
Denny G Sandwich, IL
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Oct 2005 Posts: 408 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 408 | Not the headers it's the intake. Header clearance is fine | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | As HRL stated simply shortening the arms will pollute the geometry/shifter throw. I made several attempts cutting, splicing and tacking the arms until I was happy with the shifting but it can be done with patience. Here's how I solved the issue and good luck with yours. P.S.....Denny, he's talking about intake not exhaust.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Feb 2004 Posts: 29,774 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,774 | The offset shift arms are a good idea. As long as the center-to-center distance of the pivot holes doesn't change the geometry will be about right. Jerry
| | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | When I installed a '66 Saginaw 3 speed in my '50, I had to do some creative modifications to account for the different location of the shifter arms on the transmission. It resulted in creating a geometry issue, which at first, I was not happy with. It caused the throw of the 1-2 shift to be short throw, while the 3-R remained correct. It created no issues in shifting, and in fact helped me to better determine when I was in first gear rather than third gear at a stop light. So I called it good enough, maybe even better than stock. Carl
| | | | | Joined: Oct 2005 Posts: 408 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 408 | I am going to take the shifter lever to work and get 1/4-3/8 milled out of the middle then welded back together. Will let you know next weekend how it turns out. Paul | | |
