| | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2012 Posts: 15 'Bolter | | 'Bolter Joined: May 2012 Posts: 15 | Well, this Nor'easter has barely started and I already got nailed. A 3.5" branch that I have no idea where it came from, must have been very, very high, I'm pretty diligent about checking for potential dangers, I actually looked yesterday, but I guess I missed this one.
A direct hit, passenger's windscreen, channel, cowl, dash and defroster diverter trim piece. That's all I noticed for now, there must be some collateral damage else where, unless it took a lucky bounce (it was also about 15-16' long), but I was getting sick just looking at it, not to mention wet and cold. I'm no bodyman, but looks to me like it needs to be replaced.
Body is... was in very, very good condition, but have been looking for an engine. So of course I had no insurance.
So before I have a bodyman do a house call, if that's even possible. I thought I would start tracking down parts.
Finally my question, I'm working on a '48 2 ton, are all the body parts just a little bigger? Is the glass bigger? Can I use anything from pick-ups or only 1.5 & 2 tons?
While we're on the subject, what about the engines, (pick-up v. big bolt) are there any differences I should be aware of on the truck 235, '47-'62 other than the obvious W/P, M/M etc.?
I know that was long, but if you made it this far, thanks for reading and thanks in advance for any insight you may be able to pass along.
Thanks again, D. | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | Well, it could have been worse - caved in roof etc.
Glass is easy, flat cut from your local auto glass place. The rest of the parts mentioned are standard for all '47 - '53 cabs. The front clip is the difference in the big bolts. Fenders, inner fenders etc, because of the bigger tires. | | | | | Joined: Nov 1995 Posts: 5,715 62401 | | 62401 Joined: Nov 1995 Posts: 5,715 | D -- Jim is correct -- Cabs interchange with the pickups, just be aware that the cab mounts are different '49 and later. Also, in '49, the gas tank came inside the cab so as has been observed in a different thread, if you use a later cab on a '48 chassis, you could have two fuel tanks  On the engines, after '53 ('54 and up), the I-6 engines (235's, 261's, etc) have longer water pumps (and mounted lower). If you use a later engine, you will have to modify it to use an earlier water pump (not hard) or move the radiator forward. You might also have cooling issues, depending on how you use your truck. For other differences, check out the Advance Design spotting guide in the Tech Tips (Menu is at the top of the page). Good luck, John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | |
