4 members (Stovebolt48, Steelonsteel, Bill Hanlon, lumbersawyer), 31 guests, and 2 robots.
Topics128,037
Posts1,055,466
Members48,422
#1127192 10/01/2015 12:12 AM
The wire came apart from the knob. Is there a way to repair this? Doesn't look like it would stand a re-crimp and these little cables have to pull a lot of pounds for their size. Weld? I would appreciate any replies as I don't want to buy a re-production because they just look a bit tacky and I want to maintain the original. Many thanks!!!
http://s23.photobucket.com/user/littlebuddytoo/media/48Chevy/Picture%20009.jpg.html
1948 AD Pickup
This is a perfect job for a TIG welder.
Thank you 52Carl! Now I just have to find a person who can do this. Cheers!
1948 AD Pickup
c53 Offline
Silver-solder. I did a bunch of them on small aircraft.
I did my choke cable by filing shallow notches (avoid sharp v's though - make them rounded) in the wire and then crimp the drilled out end of the rod into them. It works fine and no welding required which I could have done if I thought it was necessary. I think that is how they were originally done as there is no sign of weld or silver solder.
1950 3600
1951 4400
Gazz
Thank you c53 and Gazz! A welding guy I spoke with said that welding would only weaken the metal. I spoke with a timber supply person who does swaging and crimping for the timber industry and he said silver soldering would be best for this little job c53. Interesting little bit of fabrication you did Gazz, I'll keep your method in mind because it sounds like a great alternative if not the best method to go with. Thanks all for your help in this little fix-it!
1948 AD Pickup
