| | | Forums66 Topics128,005 Posts1,055,253 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | couldn't find a good pic to confirm which cross sills require the retainer bracket that keeps the sill from spreading seems to me all he pictures show it on the rear center cross sill Are they also on the cab end cross sill ? | | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | Not 100% sure, but it would make sense to me that they were for where ever there is a wooden block. Carl
| | | | | Joined: Mar 2001 Posts: 265 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 265 | Guys, the retainer brackets are on both on the front and the back cross sills. Carl, you are correct, they are where the wooden blocks go. There is also a rubber pad, that sits under the wooden block on your frame. The middle cross sill just floats under your bed, to hold all the bed wood and bed strips in place. Hope that helps.
Rugo
Steve Rugg 53 3100
