8 members (78buckshot, Woodcmiami, cmayna, Hotrod Lincoln, Gdads51, mick53, MickeyP, 1 invisible),
38
10
Mod | | | Forums66 Topics128,012 Posts1,055,312 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 272 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 272 | The wire came apart from the knob. Is there a way to repair this? Doesn't look like it would stand a re-crimp and these little cables have to pull a lot of pounds for their size. Weld? I would appreciate any replies as I don't want to buy a re-production because they just look a bit tacky and I want to maintain the original. Many thanks!!! http://s23.photobucket.com/user/littlebuddytoo/media/48Chevy/Picture%20009.jpg.html
1948 AD Pickup
| | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | This is a perfect job for a TIG welder.
| | | | | Joined: Jun 2006 Posts: 272 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 272 | Thank you 52Carl! Now I just have to find a person who can do this. Cheers!
1948 AD Pickup
| | | | | Joined: Oct 2007 Posts: 75 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 75 | Silver-solder. I did a bunch of them on small aircraft. | | | | | Joined: Mar 2006 Posts: 249 'Bolter | | 'Bolter Joined: Mar 2006 Posts: 249 | I did my choke cable by filing shallow notches (avoid sharp v's though - make them rounded) in the wire and then crimp the drilled out end of the rod into them. It works fine and no welding required which I could have done if I thought it was necessary. I think that is how they were originally done as there is no sign of weld or silver solder.
1950 3600 1951 4400 Gazz
| | | | | Joined: Jun 2006 Posts: 272 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 272 | Thank you c53 and Gazz! A welding guy I spoke with said that welding would only weaken the metal. I spoke with a timber supply person who does swaging and crimping for the timber industry and he said silver soldering would be best for this little job c53. Interesting little bit of fabrication you did Gazz, I'll keep your method in mind because it sounds like a great alternative if not the best method to go with. Thanks all for your help in this little fix-it!
1948 AD Pickup
