0 members (), 153 guests, and 1 robot.
Topics128,110
Posts1,056,241
Members48,437
I finally got the the old bumper off, (I ground one bumper bolt off...then decided to snap the others off by overtightening. I got it down to where I could snap one off in less than a minute.) Then I cleaned and primed stuff with Zero-Rust. After a coat of Rustoleum, I fit the new bumper on the brackets:
[img]http://chevyasylum.com/64c10/64c10_117r4.jpg[/img]
Only the end bolt holes match up. I'll have to drill new holes for the center bracket.
And I got one of the new fenders mounted up:
[img]http://chevyasylum.com/64c10/64c10_125r4.jpg[/img]
It's startin to look a little better. But the rocker panel on the right side was in really bad shape:
[img]http://chevyasylum.com/64c10/64c10_121r4.jpg[/img]
So I cut it out and fit a replacement panel in to place:
[img]http://chevyasylum.com/64c10/64c10_149r4.jpg[/img]
Yeah, I finally gave up and took the door off. I'm gonna have to fix the hinge, anyway. It has enough slop to throw a whole herd of cats thru.
Then I started bolting the grill together.
[img]http://chevyasylum.com/64c10/64c10_151r4.jpg[/img]
I'd had to grind off the rivets that attach the headlight buckets, then prime and paint them...I decided to use bolts and Nylock nuts instead of rivets. Sure makes disassembly a lot easier.
Then I went back and primed the rusty area behind the rocker panel with Zero-Rust:
[img]http://chevyasylum.com/64c10/64c10_153r4.jpg[/img]
That's where it stands as of Saturday evening. I'll see if I can get a little more done tomorrow. Like fabricating a patch panel to cover the hole in the inner rocker panel and getting the retaining springs for the headlights...and drilling out the broken-off bolts on the headlight buckets. I forgot all about that until I had the grill bolted back together. Oops.
But progress is good.
Lookin' good, Ray. I like your replacement idea for the rivets on the grill -- smart move.
Keep it up! We love the pics!!
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
