8 members (Stovebolt48, SNOYL, Hugh63c10, Cletus1950, Barnfind49, Gib70, Otto Skorzeny, klhansen),
76
Mod | | | Forums66 Topics128,281 Posts1,058,460 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2007 Posts: 71 Shop Shark | | Shop Shark Joined: Apr 2007 Posts: 71 | hello
my choke cable on my 65 2bbl is very hard to push/pull. is there something i can try to remedy this or should i just get a new cable? if so where is the best place to get one?
thanks | | | | | Joined: May 2007 Posts: 1,721 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,721 | You can try and get some lube down the shielding while it is the truck. Attack from both ends. Depending on how much time and patience you have remove the cable and tie in vertical position in garage and lube and free up the cable. Reinstall. Yes you can free it up. Likely gritted up with dust and dirt. | | | | | Joined: Apr 2005 Posts: 313 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 313 | Pulling the knob while stepping on the gas pedal is recommended by the owner's guide.
It works for me in my 1966 C10 with a 2bbl carburetor. | | | | | Joined: Mar 2011 Posts: 21 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 21 | I had the same problem, the cable could be one issue which lubing it will take care of that but you should also check the carburetor with the choke cable unhooked and moving the choke lever by hand to see if it's sticking some and if it is you can lube it as will. | | |
