Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
5 members (Wheelie, Pre '68 Dave, Otto Skorzeny, greenie-reddy, TooMany2count), 86 guests, and 5 robots.
Topics128,281
Posts1,058,460
Members48,490
hello
my choke cable on my 65 2bbl is very hard to push/pull.
is there something i can try to remedy this or should i just get a new cable? if so where is the best place to get one?
thanks
You can try and get some lube down the shielding while it is the truck. Attack from both ends. Depending on how much time and patience you have remove the cable and tie in vertical position in garage and lube and free up the cable. Reinstall.
Yes you can free it up. Likely gritted up with dust and dirt.
~ HB
1962 Chevrolet C10
1962 Suburban
Pulling the knob while stepping on the gas pedal is recommended by the owner's guide.
It works for me in my 1966 C10 with a 2bbl carburetor.
I had the same problem, the cable could be one issue which lubing it will take care of that but you should also check the carburetor with the choke cable unhooked and moving the choke lever by hand to see if it's sticking some and if it is you can lube it as will.
