5 members (60steve, Alex52, Gdads51, 2 invisible),
76
0
Mod | | | Forums66 Topics128,212 Posts1,057,465 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | I know the 1965 230 head has a different spark plug thread diameter size. That's the only difference in the heads that I know of. Then again I am always surprised at what I don't know. It's the old saying, "I don't know what I don't know". I'd rather get a 250 crank for the 230 than steal the one from my 250. | | | | | Joined: Feb 2004 Posts: 29,889 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,889 | Heads from all the recent generation of inline sixes will interchange. The 194 has smaller valves, I believe, but the 230/250/292 heads are pretty much clones of each other. Just stay away from the latest-production ones with the integral intake manifold. Those things suck line a Hoover upright vacuum cleaner, and they're prone to cracking, IIRC. Jerry
| | | | | Joined: Feb 2000 Posts: 5,243 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,243 | For the 230, I believe you use 283 flat top pistons.
Joe | | | | | Joined: Feb 2004 Posts: 29,889 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,889 | Hmmmm- - - -good idea! the compression height on a 283 piston is 1/8" taller which should work out about right with the shorter 230 stroke. I've got a 230 in the stockpile of engines I plan to build eventually- - -I'll have to remember that trick! That would make for a tight-winding little engine with the right gear ratio and carburetion.
I'm planning to put an inline 6 in an Excalibur roadster somebody gave me, with 3 Weber DCOE 40 carbs and a set of dual exhausts off a split manifold or a set of Clifford cast iron headers. I think the 230 just found a home! Jerry
| | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | Sooooo . . . . I can build the 230ci with the original 230 crank and use 283 pistons? Great! That saves me from hunting down a used 250 crank. Will it perform about the same as a 250ci? | | | | | Joined: Dec 2008 Posts: 319 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 319 | Ummm, no. The longer stroke of the 250 gives it enhanced torque characteristics compared to the 230, all other things being equal. If you can't fix it with a hammer and screwdriver, you need a bigger hammer.1965 Chevy C10 | | | | | Joined: Feb 2004 Posts: 29,889 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,889 | The 250 will have better low-end torque. The 230 will have a higher RPM capability, so the weight of the vehicle you're running and the final drive gear ratio will determine which engine will serve you best. I can probably get the same horsepower from a modified 230 as a basically stock 250, but it will be turning noticeably faster RPM. A short stroke V8 like a 302 or a 327 can outperform a 350, but it has to be modified, balanced, and wound up like a bumblebee on steroids to do it! Jerry
| | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | The 250 will have better low-end torque. The 230 will have a higher RPM capability, so the weight of the vehicle you're running and the final drive gear ratio will determine which engine will serve you best. I can probably get the same horsepower from a modified 230 as a basically stock 250, but it will be turning noticeably faster RPM. A short stroke V8 like a 302 or a 327 can outperform a 350, but it has to be modified, balanced, and wound up like a bumblebee on steroids to do it! Jerry I've driven my smoking, low oil pressure 250ci enough to know I have plenty of power and rarely go over 2400 RPMs. With the OD gear I cruise comfortably on the highway at 2100-2200 RPMs. Sounds like a 250ci will serve me best. | | | | | Joined: Feb 2004 Posts: 29,889 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,889 | There would be no problem building your spare engine as a 250- - - -just do a crankshaft swap. If the 230 crank needs top be reground, the cost would be virtually the same, since a reground 230 or 250 shaft would be almost the same price, and they will use exactly the same bearings. Jerry
| | | | | Joined: Mar 2010 Posts: 10,310 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,310 | I had a 230 with 1000,000 miles in a '70 Nova with a 3 speed. I could chirp a skinny bias ply tire (no posi) in all three gears. It was impossible to tell that the engine was still running at a traffic light too. I am a fan of the 230. Carl
| | | | | Joined: Feb 2004 Posts: 29,889 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,889 | I've never seen a million-mile 230. That must be quite an accomplishment (or a typo).
| | | | | Joined: Mar 2010 Posts: 10,310 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,310 | Bad eyes, feeble fingers, weak mind... You choose.
