| | | Forums66 Topics128,030 Posts1,055,418 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | Does any one know of a vendor who makes an assemnbly ,12 volt with directional installed
thanks ,Dennis | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 1949?
tail light assembly
Tail lights came with two bulbs or two filaments, right? Use 12v bulb(s) in the 6v socket(s).
That is all that is needed for: 1. tail light - signal light (I think) 2. brake light
For the front signal, you can get a dual-filament fixture to replace the single filament fixture. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | It would be the brake bulb used for the turn signal. I don't know how the wiring would go for turn signals but when braking both bulbs are lit. If the OP really wants to go with a single 1157 bulb there are adapters on the market. <CLICK> I bought a pair & decided my 6v are brighter with the right bulbs so I took them off and modified my original bracket. OP, if you want those brackets PM me. I'll save you some money over the vendors.
