4 members (2-Ton, jmoore, TUTS 59, WICruiser), 145 guests, and 1 robot.
Topics128,048
Posts1,055,540
Members48,425
#1125620 09/22/2015 9:32 PM
Does any one know of a vendor who makes an assemnbly ,12 volt with directional installed
thanks ,Dennis
just-a-hacker
'49 3100 before '99
1949?
tail light assembly
Tail lights came with two bulbs or two filaments, right?
Use 12v bulb(s) in the 6v socket(s).
That is all that is needed for:
1. tail light - signal light (I think)
2. brake light
For the front signal, you can get a dual-filament fixture to replace the single filament fixture.
Ex Hall Monitor
Ex Hall Monitor
It would be the brake bulb used for the turn signal. I don't know how the wiring would go for turn signals but when braking both bulbs are lit. If the OP really wants to go with a single 1157 bulb there are adapters on the market. <CLICK> I bought a pair & decided my 6v are brighter with the right bulbs so I took them off and modified my original bracket. OP, if you want those brackets PM me. I'll save you some money over the vendors.
