3 members (moparguy, texas46, Gray_Ghost), 191 guests, and 3 robots.
Topics128,108
Posts1,056,236
Members48,437
Have some outside door stainless trim from a 1950 3100 will the trim fit other 3100 years ?
1947-1950, the trim is not designed to fit the Venti-pane doors introduced in 1951.
KMAC
Brad, could the outside trim be made to fit the vent-pane doors without much work? What prevents them from fitting? I know that the inside trim is quite a bit different and does not work. …………………..g
I believe they could be made to work if they are coped correctly for the vent window.
thanks for the help Brad
Haunting the SBP since 2001
KMAC
nono
All 1947.2 - 1955.1 OUTSIDE stainless door trims are identical & will interchange to any Advance Design truck.
The INSIDE trims are the ones that are different.
It is tough to "notch" the inside '47-'50 trims to fit the '51-'55.1 doors with the vent windows as the earlier trim is narrower & won't lip on the door correctly.
I have seen this SS piece on a 54 truck (with vent windows). I can't attest to its originality.
(deleted ad)
Is there a good way to buff and polish both outside and inside stainless trim?
Dennis
Just about every one offers SS polishing kits, Jegs, CMS, Caswell on and on.
A Google search of "Polishing Stainless Steel" will bring up
enough info to keep you reading the rest of the day. Anything
from using your Harbor Freight 1/4" drill to big old full
sized buffing pads mounted on Baldor buffers that will take
your trim out of your hand and throw it across the room.
Buffing is easy, fun and very rewarding in the way it looks,
after the mess is cleaned up.
Note: just make sure it really is SS and not chrome plating
that your buffing.
dg
Denny G
Sandwich, IL
Thank you Denny. Are all these kits the same? And I assume using a simple magnet will tell if it's chrome or stainless
Dennis
Should but some of the SS can offer a slight pull to a magnet.
Steel will give it a strong pull.
I would say that any of the kits would have the same or similar
buffing compounds. Your SS trim should already be polished,
all you need do is buff out the minor surface scratches that
have accumulated over the years. Sort of a tough up.
dg
Denny G
Sandwich, IL
Thank you again
Dennis
