3 members (55shaker, Bill Hanlon, 1 invisible), 76 guests, and 3 robots.
Topics128,037
Posts1,055,463
Members48,422
#1125072 09/20/2015 1:19 AM
Hi guys. I am removing the engine from my 1948 chevy 1 ton. I have about everything disconnected except the engine mounts. How do I remove/disconnect these? Thanks.
Bryce S. #1125090 09/20/2015 2:38 AM
First you will need to do an archaeologic excavation of the grease/oil/dirt to find the bolts which go straight down through the crossmember. I believe that they have 5/8" heads on them. You can remove these two bolts and pull the engine/clutch housing with the motor mounts still attached.
Carl
Bryce S. #1125165 09/20/2015 3:45 PM
Ok, thanks. What about the front ones?
Bryce S. #1125182 09/20/2015 8:20 PM
Two nuts accessed through the crossmember.
Bryce S. #1125296 09/21/2015 9:29 AM
A real good place to start is with a pressure washer so you can
see what your doing.
dg
Denny G
Sandwich, IL
dg
And take all of the fun out of it? smile
Carl
