3 members (Hotrod Lincoln, Bill Hanlon, ranchojuan), 94 guests, and 1 robot.
Topics128,047
Posts1,055,538
Members48,424
#1124757 09/18/2015 3:58 AM
Hi all, I just became proud owner of a '51 6400. In decent shape, will post pics soon as I figure out how to. In mean time, my first question is for the vacuum two speed rearend, the selector is a On the dash for the 2 speed. any way to move this to shifter like more modern 2 speed setups?
Thanks and look forward to learning and putting my truck on road again.
Huffy #1124782 09/18/2015 12:47 PM
Welcome to the bolt Huffy. Lots of good information and great people on this forum. Hopefully someone will chime in on the selector switch. All three of my big bolts are single speed rear ends, so I won't be a big help there...
Good luck with your project. Also there is not a way to upload a picture to this site. You best bet is to upload them to someplace like photo bucket and post a link to that page.
Randy Domeck
Indianapolis Fabrications
[email protected]
Indianapolis, In. 46254
317-258-0039
Huffy #1124787 09/18/2015 1:23 PM
I recently made the post for "Vacuum switch rebuild" and will be assembling it in the next couple days. I'll post my results. Hopefully someone else who has already done it will respond about shift speed and precision.
I saw your post ..thank you will definitely keep up with that info
Huffy #1124958 09/19/2015 3:58 AM
ok please let me know if this whole link to picture thing works ohwell
https://onedrive.live.com/redir?resid=58EEA391E59D0FF0!807&authkey=!AMced2uJtjvoRNE&ithint=folder%2c
Huffy #1124963 09/19/2015 4:50 AM
Welcome to the Stovebolt wave
Your link worked for me! Nice truck, what are your plans?
The 55 and up trucks with 2-speed rears had the vacuum switch mounted on the drivers side of the transmission with a push/pull control cable going up the gear shift lever.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Mike B #1124971 09/19/2015 6:20 AM
My plan is to turn it into a shop truck, Mount my welder and such on it. So want to keep truck stock, but reliable. Thinking light sanding and clear coat , don't need fancy paint for gravel raids and welding ? So will definitely be looking for help as I move forward.
Huffy #1124989 09/19/2015 1:50 PM
That's the vacuum switch I'm changing to electric because it only works 1 out of 4 times I operate it. If I can fight through the dirt enough to actually remove it, I'll post pics.
Huffy #1125197 09/20/2015 9:29 PM
Crusing in the Passing Lane
There is something to be said for keeping it all original, even though it is a pain to reach up on the panel every time one wants to shift.
Hoses leaking might the reason for intermittent operation.
