Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
2 members (baldeagle, GMCJammer51), 41 guests, and 3 robots.
Topics128,004
Posts1,055,246
Members48,418
#1124507 09/16/2015 7:45 PM
So I collected all the parts over the years and test fit the wood, of course my bedwood came without any holes
after getting truck back from paint, also realized cross sills only had mounting holes, no bed wood holes
A whole new job to tackle, made a template for cross holes , its the four corners into the sills that are going to be fun trying to mark and drill
just-a-hacker
'49 3100 before '99
just-a-hacker #1124606 09/17/2015 4:49 AM
Fox Offline
I believe the bed wood should only have holes drilled along the outside two planks for the length. Two other boards will have holes for the anchor bolts to the frame. It was this way for my one ton. Weird that your cross sills don't have holes in the top for the bed strips to bolt to.
Perhaps wait to drill holes unless you're sure of everything. We'd hate for you to wreck your boards! Someone who has more 1/2ton experience will chime in I'm sure!
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
just-a-hacker #1124608 09/17/2015 4:58 AM
U
U Offline
I think our member (& contributor/company) Mar-K has the wood spacing patterns on their website for those wanting to do their own bed work.
Let us know how it works out & what you decide. How'd you decide or figure out your template?
Brad
Wrench Fetcher, PhD
Uncle Brad #1124665 09/17/2015 4:19 PM
one of the center cross sills had holes, so I transferred those to a piece of oak, the marked rear sill with this.
Test fit of wood and trim looked good
working slowly on this so as not to ruin boards
noticed that outside boards were not up against one of the bed sides, it may be warped a little (approx 1/4) in the center.
I am going to try to pull that in then mark hole locations
just-a-hacker
'49 3100 before '99
just-a-hacker #1124699 09/17/2015 7:44 PM
I think I have a plan for the four corners ,into the sill plates
Since I cannot get to the spots from underneath,and from above I cannot get a drill close enough to keep the drill perpendicular, I will get a 9" long drill extension and a 12" long drill.
That should get me high enough to drill a perpendicular hole through.(if I mark and drill the side bed wood first ,it will act as a guide down to sill)
just-a-hacker
'49 3100 before '99
just-a-hacker #1124764 09/18/2015 5:20 AM
Fox Offline
I had the same problem with my outside boards not sitting flush against the bed side under the angle strip. I eventually shaved off about 1/16" on each side. I triple checked before cutting though! This also helped set the board gaps and strip gaps perfectly.
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
Fox #1124851 09/18/2015 7:56 PM
bought the sills a while ago and didn't know better
a lesson learned
( had no old parts to compare to )
just-a-hacker
'49 3100 before '99
just-a-hacker #1124855 09/18/2015 9:04 PM
just-a-hacker #1124866 09/18/2015 9:39 PM
thanks, I have that printed out
just-a-hacker
'49 3100 before '99
just-a-hacker #1125322 09/21/2015 1:06 PM
a little more checking revealed that the bed would is straight and the bed sides are not.
Now trying to figure out a good way to straighten or trim boards to get a good fit before drilling any holes.
just-a-hacker
'49 3100 before '99
just-a-hacker #1126021 09/24/2015 5:04 PM
clamped bed wood to bed sides to (straightening bed sides) and marked bed side holes
Then measured and marked bed to frame hole locations ( triple checked)
will look at again before drilling any holes
just-a-hacker
'49 3100 before '99
