0 members (), 93 guests, and 1 robot.
Topics128,055
Posts1,055,782
#1124049 09/14/2015 12:35 AM
54 Chevy 4400 the front cylinders 7/8" are no longer available at Napa but they have a 1" with the same exterior size and mounting. How much will going from 7/8" to 1" affect the braking? am I better to send my 7/8" out to be bored and sleeved?
ROUGIE #1124085 09/14/2015 3:28 AM
Crusing in the Passing Lane
More powerful brakes, if enough volume. Are you looking for '54 Chevy or by casting number on the cyl?
ROUGIE #1124163 09/14/2015 6:15 PM
I was looking by year 1954 and model 4400 1.5 ton. The casting numbers are 5454 385. I might be able to hone these out (kits are available).
ROUGIE #1124253 09/15/2015 2:30 AM
A change from 7/8 to 1" will result in about 30% more force on the front shoes and need 30% more volume of fluid for the same shoe adjustment. This will affect brake balance and give a longer brake peddle. My opinion is to stick with the original size.
ROUGIE #1124276 09/15/2015 4:41 AM
By installing a Wilwood 10 psi residual pressure valve after the master cylinder, the volume is not a problem as the necessary fluid will stay in the wheel cylinders. The additional braking with less pedal effort may be appreciated.
ROUGIE #1124406 09/16/2015 1:28 AM
You should keep with the 7/8". When you start changing bore size you will need to make corresponding changes with the bore of the master.
Rebuild kits are cheap. Hone them slightly and put new rubber in. If you still have problems you can then send them in to be rebuilt.
Randy Domeck
Indianapolis Fabrications
[email protected]
Indianapolis, In. 46254
317-258-0039
ROUGIE #1124500 09/16/2015 6:27 PM
Don't even bother honing if they are pitted.
ROUGIE #1124503 09/16/2015 7:03 PM
I have had better than 50% success on honing pitted bores. Less than ideal? Yes. The ones on my 46 were very pitted. I expected to have them sleeved, but decided I would take my chances. An hour later I bleed the brakes and I have not had any issues with them in almost 3 years.
My point is, is that you will not spend very much time or money to see if they will work it and it will keep you on the road.
Randy Domeck
[email protected]
317-258-0039
ROUGIE #1124979 09/19/2015 11:04 AM
I may have the cylinders you need call me 1-262-392-2989
Marv.
