4 members (cmayna, baldeagle, Gray_Ghost, Phak1), 80 guests, and 4 robots.
Topics128,017
Posts1,055,338
Members48,419
#112443 04/04/2005 10:22 PM
I've got a 47 AD. The hood won't close all the way, although it will latch. When closed, it looks like it's sitting up about 1 1/2 inches up AND out from the mounts, but it looks fine from underneath. Any tips? Thanks,
jay
Your lack of preparation is not my emergency
#112444 04/04/2005 10:32 PM
try it without the springs on, if it sits right replace the weak springs!
#112445 04/05/2005 3:22 AM
Anonymous
Unregistered
Anonymous
Unregistered
I have the same problem. When the springs are off it does sit right...guess I need new springs...
#112446 04/05/2005 3:42 AM
Could you explain this to me please? I will want to know about this when I get there. Are you talking about the main hood springs and if so, how do they affect the position?
thanks,
Fred
1951 1 Ton Completed
#112447 04/05/2005 4:24 AM
yes, the springs on the hood hinges - actually it could be the hinges themselves, but the springs are easier to swap - if the hinge pivots are worn [they all are by 50 years later] the springs will pull things into the wrong position when the hoods closed, but also can be a result of weak or unbalanced springs - my 58 was like that when I got it and got better w/ a different set of used springs, then worse later after the paint was done and the hood had been off and on twice, I think cuz I oiled the hinges well eek new hinges and springs fixed it immediately
#112448 04/07/2005 8:46 PM
Anonymous
Unregistered
Anonymous
Unregistered
There is a specific alignment procedure for AD hoods. I have sent it to you via email. This was found on another site.
#112449 04/07/2005 8:54 PM
Houston, Can you post a link to that other site? I am about to tackle this problem and it looks like there are others interested too.
Gord
1954 1/2 ton 235 4 speed
#112450 04/08/2005 12:33 AM
Anonymous
Unregistered
Anonymous
Unregistered
#112451 04/08/2005 7:04 PM
Thanks for the link. Looks likes it will be another fun job.
Gord
#112452 04/08/2005 10:40 PM
Gord, let us know how it goes--I have to tackle the same job on my 54. (There's too much gap along one side. Also the fender on that side looks to be set a little too low.)
Christian
#112453 06/12/2005 1:51 AM
Junior Member
Junior Member
I've got the same problem on my 53' i just changed both of my fenders and know there is a gap on the right edge. before i changed them it was perfect.
If ain't broke Break it and fix it.
