1 members (baldeagle),
38
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 168 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2004 Posts: 168 | I've got a 47 AD. The hood won't close all the way, although it will latch. When closed, it looks like it's sitting up about 1 1/2 inches up AND out from the mounts, but it looks fine from underneath. Any tips? Thanks,
jay
Your lack of preparation is not my emergency
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | try it without the springs on, if it sits right replace the weak springs!
Bill | | | | | | Anonymous Unregistered | | Anonymous Unregistered | I have the same problem. When the springs are off it does sit right...guess I need new springs... | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Could you explain this to me please? I will want to know about this when I get there. Are you talking about the main hood springs and if so, how do they affect the position?
thanks, Fred | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes, the springs on the hood hinges - actually it could be the hinges themselves, but the springs are easier to swap - if the hinge pivots are worn [they all are by 50 years later] the springs will pull things into the wrong position when the hoods closed, but also can be a result of weak or unbalanced springs - my 58 was like that when I got it and got better w/ a different set of used springs, then worse later after the paint was done and the hood had been off and on twice, I think cuz I oiled the hinges well  new hinges and springs fixed it immediately Bill | | | | | | Anonymous Unregistered | | Anonymous Unregistered | There is a specific alignment procedure for AD hoods. I have sent it to you via email. This was found on another site. | | | | | Joined: Jun 2004 Posts: 336 Member | | Member Joined: Jun 2004 Posts: 336 | Houston, Can you post a link to that other site? I am about to tackle this problem and it looks like there are others interested too.
Gord 1954 1/2 ton 235 4 speed
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | | | | | | Joined: Jun 2004 Posts: 336 Member | | Member Joined: Jun 2004 Posts: 336 | Thanks for the link. Looks likes it will be another fun job.
| | | | | Joined: Apr 2005 Posts: 151 Member | | Member Joined: Apr 2005 Posts: 151 | Gord, let us know how it goes--I have to tackle the same job on my 54. (There's too much gap along one side. Also the fender on that side looks to be set a little too low.)
Christian | | | | | Joined: Oct 2004 Posts: 27 Junior Member | | Junior Member Joined: Oct 2004 Posts: 27 | I've got the same problem on my 53' i just changed both of my fenders and know there is a gap on the right edge. before i changed them it was perfect.
If ain't broke Break it and fix it.
