| | | Forums66 Topics128,035 Posts1,055,570 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#11243 05/17/2005 5:52 PM | Joined: May 2005 Posts: 13 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 13 | I have a 235 straight six. When I bought the truck it had a lot of chatter. So I pulled the head and had it rebuilt and replaced all the pushrods. 6 of them where bent. Bolted all of it back together and I can't get the truck to start. It does have a different carb(no manuel choke) replaced points and condenser, cap, plugs and wires. It does get spark and occaissonal back fire but still won't start.I was wondering if the timing could be out or is it possibly in the carb. | | |
#11244 05/17/2005 6:40 PM | Joined: Feb 2004 Posts: 336 Shop Shark | | Shop Shark Joined: Feb 2004 Posts: 336 | Just some advise for the future, Take it one step at a time.
I'm new to 235s' also and have learned a lot from all the great members hear. I don’t move on or change anything until the first problem is fixed. That way I don’t end up in a sea of problems with multiple fixes and multiple symptoms.
Billy | | |
#11245 05/17/2005 7:17 PM | Joined: Sep 2004 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2004 Posts: 51 | Amt31,
Just as Hamonthebone said above, you should focus your troubleshooting on the things you replaced or repaired. It sounds as if you might want to check your new plug wires and make sure that they are attached to the cap in the correct 1-5-3-6-2-4 firing order. If they are out of order the ignition timing will be off and you will get random backfiring and no start as you described. The easiest way to make sure that they are correctly installed is to work your way around the distributor cap in a clockwise direction and tracing each wire from the distributor cap to each spark plug.
Start at the wire leading to to the cylinder number 1 plug (the plug for number one is at the front of the engine / the cylinders are numbered one to six from front to back) and continue tracing the wires from plug to cap in a clockwise direction around the cap. The next wire in your clockwise trip around the distributor cap should lead to cylinder #5, the next one should lead to #3, the next one to #6, the next to #2 and the next one to #4. After #4 you should be back to #1 and have completed a igniton firing order.
If the wires are in their correct positions and you did not remove the distributor the ignition timing ios most likely ok and you can move onto other things that can cause a no start such as insufficient valve clearance causing a loss of compression, a faulty carb and/or some other fault. The new carb shouldn't cause a no start problem unless it is not correct for your application and/or is in dire need of a rebuild. What kind of carb did you replace the manual choke carb with?
Sorry for the long post and welcome to the bolt. I hope you get her running. | | |
#11246 05/17/2005 7:17 PM | Joined: Jan 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 310 | I learned that lesson the hard way. I was working on an Allis-Chalmers WD-45 and gave it a tune and rebuilt the carb at the same time. When I was done, it wouldn't start. I had 2 systems I had to check out instead of only 1 if I had done it in steps.
Anyway, in my opinion, not being there to check it out, it sounds like it could be timing.
-Tim '51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
#11247 05/17/2005 10:32 PM | Joined: May 2005 Posts: 13 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 13 | I replaced the carb with a rochester rp it has a vacume choke. The distributor cab and wires where removed by my brother and he didn't mark anything, I've set the valves according to the instruction on this page. | | |
#11248 05/17/2005 10:51 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | These are all good sugestions. Are you getting gas in the carb? Did you try priming it. If you can,t get it started with this help I will come get it started. I,m about 30-40 miles from Pleasanton. George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#11249 05/17/2005 10:59 PM | Joined: May 2005 Posts: 13 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 13 | George I have primed the carb and the fuel pump. It is pumping gas and I get gas in some of the cylinders but not all. | | |
#11250 05/17/2005 11:21 PM | Joined: Sep 2004 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2004 Posts: 51 | amt31,
Since your brother didn't mark the wires, I would start with the plug wires. The igntion timing is most likely off and the engine will not run until the timing is set correctly. In my earlier post I tried to give you some help in checking the wires. Provided that the distributor was not removed it should be fairly easy to correct the problem with the plug wires. However, since all of the wires were removed and not marked you are first going have to get the #1 cylinder on top dead center. When cylinder 1 is at top dead center the distributor rotor will be directly under one of the six spark plug terminals on the cap. This terminal will be the terminal for the #1 cylinder and the wire leaving this terminal is connected to the spark plug on the #1 cylinder.After you have got the plug wire for number one leading from its terminal on the distributor cap to the spark plug for cylinder number 1, the rest of the plug wires can be installed. Just keep the firing order and clockwise rotation of the distributor in mind when you wire 'em up
The following post will give you some additional help with setting the timing on your engine.
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=2;t=003622#000003
Good Luck | | |
#11251 05/17/2005 11:40 PM | Joined: May 2005 Posts: 13 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 13 | I did bring No1 cyl up to fire and aligned the dot on the flywheel. Put the plug wires in order from there. When reversed it did back fire through the carb. So I put them back again. I have set the valves twice. thank you for the tips. | | |
#11252 05/18/2005 12:10 AM | Joined: Dec 2003 Posts: 510 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 510 | One other thing to check is the valve lash. I've set them too tight and when the motor cranked over, it would just spin because the valves were being held open. As a result, there was no compression and no firing. It would backfire occasionally when trying to start it.
I'd make sure the plug wires were correct, and if it still doesn't start, recheck the valve lash. | | |
#11253 05/18/2005 1:56 AM | Joined: May 2005 Posts: 13 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 13 | I thought I set'em to tight the first time so I loosened'em up and tried still the same so I reset them again. What method are you using to set the valve lash? | | |
#11254 05/18/2005 3:21 PM | Joined: Feb 2004 Posts: 336 Shop Shark | | Shop Shark Joined: Feb 2004 Posts: 336 | Here is an annoying thing that happened to me. I bought the truck from a towing yard (they said it ran when they towed it) I was getting gas and a spark  (i like that name) but it wouldn’t run. Come to find out some one wired the coil directly to the ignition to starter wire. | | |
#11255 05/18/2005 3:36 PM | Joined: Jul 2002 Posts: 4 Junior Member | | Junior Member Joined: Jul 2002 Posts: 4 | This is a problem I just had: I reassembled a 4 cyl tractor engine, had checked the fireing order over three times so I "knew" it was correct. Trouble is that the rotor was going different from the way I thought. I was lucky the engine started and ran on cyl 1 and 4. That gave me the chance to switch the 2,3 wire, and the engine ran fine. | | |
#11256 05/18/2005 10:45 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Hey Amp31. Have you got it started yet? Update us & if nessesary I,ll come out there. George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#11257 05/18/2005 10:58 PM | Joined: May 2005 Posts: 13 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 13 | No I haven't got it started yet, plan on working on it this weekend if its nice. Unfortunaley no room in garage. Was digging around and found a carb with manual choke off a 216. Just need to swap lower plate. Hope this gives me gas to the cylinders. Got to checking and the wiring has been changed it used to be a 6 volt generator been converted to 12 volt alternator so I need to check out all the wiring under the hood. Hate trying to figure out other peoples work. Thank you for the offer wrenchbender I'll keep you all posted on the progress. | | |
#11258 05/19/2005 9:22 PM | Joined: May 2005 Posts: 13 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 13 | Alright finally a beatiful day, started taking the 216 rochester apart to transfer lower plate, the vacume choked rochester was missing the little arm that runs the accelerator, go figure a $20 salvage yard carb missing parts ha,ha, that never happens. Waiting on rebuild kit and am going to try it again. Hopefully fingures crossed it'll start. Thank you everyone on the advice and tips this is a really excellent site. Wish me luck. | | |
#11259 05/21/2005 8:03 PM | Joined: May 2005 Posts: 13 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 13 | Ok different carb on and its still won't fire off.It will back fire, so I rotated all the plug wires all the way around the cap still no luck. Could timing have jumped? How do you set the timing on a 235? Probaly should invest in a manual just short on funds right now. | | |
#11260 05/22/2005 7:36 PM | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | Check the firing order again. I made this mistake a while back. Drove me nuts, and everybody else who was trying to help me. The backfire is the giveaway.
delete my account and pictures
#11261 05/23/2005 3:54 AM | Joined: Sep 2004 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2004 Posts: 51 | amt31,
On the bellhousing immediately above the starter you will see a hole. In this hole you will see a pointer. This pointer is used to set the timing with the BB shaped ball on the flywheel. When the pointer is pointing to the BB on the flywheel and #1 cylinder is at top dead center on its compression stroke the timing is close enough to get the engine running.
I watch the valve rocker arms in order to get the engine TDC and firing. In other words, I remove the valve cover and watch the movement of the rocker arms in order to determine when # 1 is at top dead center and on its compression stroke.I accomplish this by turning the engine over by hand and watching the intake rocker for #1 (the second rocker from the front on the head) until it just closes the valve and then continue turning the engine over with my finger over the plug hole for #1 until I no longer feel air trying to escape from the cylinder. At this point, I remove my finger from the plug hole and keep turning the engine over by hand until the pointer in the hole on the bellhousing aligns with the bb shaped ball on the flywheel. When the ball lines up with the pointer, #1 is at top dead center and in the firing position.
When the ball and the pointer are lined up I remove the distributor cap and look at the points. If the they have just started to break, the timing is close enough to get the engine running. If they have not, you will have to loosen the screw that goes through the clamp on the distributor and rotate the distributor a little bit until the points just break. This screw and clamp are located where the distributor shaft inserts into the block. After the points are adjusted to just break tighten the screw on the distributor clamp so the distributor won't spin out of time when you try to start the engine.
At this point the rotor will be immediately under the terminal in the cap for the #1 cylinder and you can re-check your plug wires. The easiest way to do this is to start at the plug wire for #1 and work your way around the distributor cap in a clockwise direction. The wire after #1 should lead to #5, the wire after #5 should lead to #3, The wire after #3 should lead to #6. the wire after #6 should lead to #2, the wire after #2 should lead to #4 and the wire after #4 should lead to #1 and you will have completed yor clockwise plug wire chasing journey around the distributor cap.
After you get it running final adjustments can be made with a timing light by re-loosening the distributor clamp and rotating the dizzy until the pointer aligns with the bb shaped ball on the flywheel and/or by vacuum gauge by rotating the dizzy until the highest vacuum level shows on the gauge.
I hope this helps. Good luck getting her going. | | |
