| | | Forums66 Topics128,072 Posts1,055,903 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 170 Shop Shark | | Shop Shark Joined: Feb 2011 Posts: 170 | I need input on the best way to paint the graphics on my newly chromed grille, and grille emblem. The original was sprayed is there a stencil available to aid in doing this? Also what is the name of the blue color used on the grille and hubcaps. Thanks, Scott | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | I used sanded the chrome then used an etching primer. I taped and cut each lrtter with an exacto knife. | | | | | Joined: Feb 2011 Posts: 170 Shop Shark | | Shop Shark Joined: Feb 2011 Posts: 170 | What did you sand with, scotchbrite or sand paper, and what grit? I'm scared to skuff my grille but I know it is necessary for the paint to stick and it looks better with the letters highlited. By the way your truck looks awesome! | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | I would not sand the chrome with anything. An alcohol based metal prep solution should clean the surface for a paint bond. | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | I was advised by a local good restorer to lightly sand or bead blast the wide band that runs across the top of lower grill, then primer and paint. the other stripes and details of emblem did with pinstripe tape and wider red and blue tape which I applied then trimmed with an exacto knife. | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | I used 600 grit silicone carbide ,wetdry, then the etching primer. Thanks for the complement. | | |
